spark plug thread size
Started by honeybadger, January 08, 2013, 03:03:47 PM
honeybadger
Howdy guys, I can't quite tell what the thread size is on our spark plugs.
Need to know because I need to buy a leakdown tester and need to have the proper adapter (obviously)
oldktmdude
Quote from: honeybadger on January 08, 2013, 03:03:47 PM
Thread diameter is 12mm, thread pitch is 1.25mm and the reach is 19mm.   Regards, Pete.
1985 FJ1100 x2 (1 sold)
2009 TDM 900
1979 Kawasaki Z650 (sold)
2001 KTM 520 exc (sold)
2004 GasGas Ec300
1981 Honda CB 900 F (sold)
bigbore2
or you could do what I did and buy a leakdown/compression tester [I am assuming they are the same?] with a 14mm end thinking the mm designation would be for motorcycles because it is millimeters and an auto designation end would be American units.  then when I tried to screw the tip in it would not fit and I spent WAY too much time trying to get that tip to fit before I realized it was the wrong size.  Yep, now I need to get an adapter also.  14mm to 12mm.
That should not be too hard to find, eh.
bigbore2
I used an old spark plug with the center ripped out, welded an air fitting to it, and works great for leak testing and compression tests
