Fuel Tank Swaps.
Started by Woodsman, December 10, 2012, 08:40:53 AM
Woodsman
The tank off my "87" is not in the best condition and whilst in the process of cleaning it up i have discovered a pin hole leak. I think the tank is repairable with a little braising and a good clean out ( electrolosis maybe ). Anyone had any success with other products or repairs to a pin hole?
Worst case scenario is another tank so which years will swap on to mine?
"Man who chops his own wood heats himself twice"
87 fj1200,TBS,Daytona 900,NC30.
good news is all fj fuel tanks fit all years . with some minor differences.
a direct swap would be 86-87.....84-85 is a wee bit larger fuel capacity and a different gas cap and pet cock.
89-93 uses a fuel pump so the fuel line and petcock are different but usable.
california tanks have smog vents that can be plugged and then used as normal.
so the short answer is use any tank and just swap your current petcock onto it. :good2:
to the point of repairing your tank , a product for sealing your holes is CREAM tank coat. This forms a plastic like sealant inside your tank and works well.
there are other products as well out there ,just make sure you prep the tank well with a cleaner that takes care of any rust inside.
be patient with the setting up seal process if you rush it or the temp is off you will have a problem.
good luck.
tqmx1
Mark,
You are a bit off. The 84 through 87 are bolt on's the 89 & up tanks will fit on the bike but the petcock has a different bolt pattern so the vacuum petcock will not fit.
Kim
Unless they have changed their product, I do not recommend Cream. BTDT what a mess.
In my opinion, Por 15 is a much better product. Follow the directions closely.  It's all about proper prep work.
Cheers  Pat
Bad experiences with CREAM too. Would try POR-15 like Pat recommended -- no personal experience, but is where I'll put my time and money next time
Flying Scotsman
My 84  gas tank looks good outside,inside is crap.Just read up on Por-15.
http://www.por15.com/Data%20Sheets/cycle%20tank%20repair%20kit.pdf
might give it a try some day.
Scott.....
1990 FJ1200
1999 GP1200 (165 + hp)
Quote from: tqmx1 on December 10, 2012, 12:39:56 PM
Mark,
Kim
Thanks for the correction Kim , I will adjust my notes.
Woodsman
Think if i do go down the sealer route i'll go with the por15. My only reservation is the nature of our tanks with all the ripples on the bottom might make it tricky to get an even coat. As has been said it's all down to the prep. Have been swishing around a light chain inside and it's coming up pretty good so far.
I've fixed tanks with galvanized rivets and silver soldered over the top, underside of tanks anyway,, por 15 works great.
Here is some info and photo's of a tank cleaning. They used POR 15. As a note mine came with a "Kream" coat in it when I bought it and hasn't given me any problem. As a matter of routine maint I do change out the fuel filter once a year. I have never noticed any crap in it but I think its one of those over looked filters.http://www.svrider.com/forum/showthread.php?t=154997&highlight=tank+rust+removal
I don't know if it is the preferred way but I keep my fuel tank topped off during the winter with additive. It should not be to hard to locate another tank for your bike and with a used one I would clean and seal it just because. Good luck and riding..
I have an 86/87 tank, but it was stripped of paint so some work is required to look nice.
Woodsman
Quote from: FJmonkey on December 11, 2012, 10:40:04 PM
Shipping too expensive from you to me, but thanks for your consideration. You never know when you might need it yourself.
Does anyone use a filter on an 87 gravity fed system? Are there issues with restrictive flow?
yamahaox66200
I have a 87 FJ 1200 that I am parting out and a fuel tank in great shape, with no issues mine is red/white. If that happens to be the color you need and you are interested, let me know and I can email some photos and we can work out a price
Woodsman
Quote from: yamahaox66200 on December 14, 2012, 12:32:48 PM
Will keep that in mind should my one prove to be beyond repair, but think shipping could prove too costly./quote]
Bozo
I have a different set of carbies on the bike now which don't like the fuel pump so currently I have the fuel direct from the tap but I know that if my carbies leak I'm in trouble. Mark made a comment that the petcock is different to the 87 models (my fj is 3CV 1990).
My question, is there a vacuum petcock that fits my tank direct.
