Where does the boost sensor vacuum line go?
Started by DarthLoser, November 16, 2012, 11:35:25 AM
DarthLoser
I just bought an '89 FJ1200 and I live in California, so I have lots of extra stuff for emission requirements.  So I'm doing a tune-up and I find a vacuum hose that's broken near the carburetor.  I follow this hose up to the front of the bike near the headlight and it's connected to a boost sensor.  Where did the other end go?  I can't find a vacuum diagram that include a boost sensor, can I get some help???
Thanks!
Not sure about the Cali model, but check out the intake boots.  Each of the four boots have a port, one vacuum line should go to your petcock, one to the boost and the other two should have caps on them.  And a bit of advice, take some time to introduce yourself in the intro section...
'93 Yamaha TDM850 (x2)
'06 KTM 200XC
'43 BSA WM20
The vacuum line attached to the intake manifold port on the #2 carb.
'89 has a fuel pump, no vac to the petcock... So , only one vac line.
DarthLoser
Thanks for the help guys!  The bike's running a lot better now.  Thanks again.
