4 brush starter motor
Started by fj11.5, November 12, 2012, 02:54:24 AM
The 89 has had issues ever since my cousin owned it with the starter motor, , ok when cold but once warm and trying to re,start sounds like a flat battery , he had cleaned the com and brushes to no avail ,, so today I took it out and about to POP the top , didn't really need too as going by the numbers its a two brush unit as fitted to 1100,s ,, opened it any way , and sure enough That's what it is,, didn't bother cleaning it, just grabbed a cleaned and ready to use 4 brush unit off the shelf, fired to really well cold , better than it had been , so after a good run when I can ill see if the problem is solved , all connections are clean and rear earth on engine is good  :biggrin:  took longer to type this on my phone than do The deed
radiotek
I would expect the dual winding armature too go harder than the single? all working I hope?
1988 XJR1300
Going to give her a Goood run tomorrow, should find out if its going to do the flat battery attempt
