What to do first?
Started by keand3, October 08, 2012, 12:34:34 PM
WhiteBeard
Quote from: keand3 on October 14, 2012, 01:06:10 AM
Aha, i knew there were something that i had missed.
The hunt for a new front wheel have begun. Luckely i have 6 months of winter to find one  :good2:
Ken
While you're at it, you might also look for another brake master cylinder (14mm being the most popular alternative me thinks).
It gives you a much nicer feel.
Here's some links for ya:
http://www.fjowners.com/index.php?topic=6599
http://www.fjowners.com/index.php?topic=1380
And don't forget to change the brake lines to braided ones.
Then you could install Randys fork valves and fork brace, then... then...
Koookalooooo!!!!
:yahoo:
Nat
keand3
Thanks for the tip Nat.
Wil deffently look into it  :good2:
Last night i was supposed to take my fork of, but never got that far. (were supposed to pick up my new 89 fork and the blue spot calipets in exchange for the old fork)
Turned out the fairing waden't as easy to take out as i tought. Over the years all bolt, nuts and screws ave been change to different types, and everything made of rubber needs to bee changed. Were a nightmare getting it of without breaking anything :nea:
So i found a website fron The Netherlands/Holland that had allmost every stock item to FJ modells, not so bad prices either. http://www.cmsnl.com/
Ken
keand3
Quote from: Pat Conlon on October 11, 2012, 12:00:51 PM
Look up the part# and send Randy a e-mail. He can get you oem parts.
Randy's on case, what an excellent service!!
keand3
Quote from: WhiteBeard on October 13, 2012, 03:50:01 PM
Quote from: keand3 on October 13, 2012, 03:04:24 PM
I stil l only have stock front wheel and brake disc, will the new calipers work on stock disk?
You need a later model front wheel (89+) or even better, a 3.5'' FZR1000 wheel (87-88). The Blue Dots will not bolt onto the earlier model wheels.
Here's a great guide that will tell you all you need to know about the upgrade.
Good luck!
/Nat
Nat, this is the awnser i got from an used part deler regardig my question  if he had a 87-88 FZR1000 wheel in store that i could bolt on my 89 fork ( same guy who will deliver my mew fork)
"You should probably not try them they do not fit use one fj1200 wheels"
Am not really sure what his awnser is based on thoug..
Is there other parts than from a stock 89 wheel would need to bolt on a FRZ1000 wheel ?
It seems that a lot of dealers should have taken a trip to the fjowners forum for an update on information  :pardon:
Ken
It's the same wheel as the FJ wheel, only it's 3.5" wide....the dealer is wrong. We know more than he does.
Everything that fits the 17" FJ wheel, fits the '87/88 FZR rim, axle, spacers, speedo drive, rotors, everything.
keand3
Quote from: Pat Conlon on October 15, 2012, 11:36:52 AM
It's amazing how people you would consider as professionals, lack knowledge regarding parts, comaibility and so on... After all the information i have received here in this FJ comunity, there is no doubt in who i trust :greeting:
Quote from: keand3 on October 15, 2012, 01:51:50 PM
You can trust Pat...he knows his shit and isn't afraid the share it!
To be honest, most everyone here is about the same, damn good bunch!
Right on Leon... :drinks:
We have a unique community here.
We eat, sleep, breathe FJ's. Currently we have 2,674 members worldwide, and we all bring something to the table.
It's the power of the increment. Between us, we have many, many years of collected experience.
keand3
Quote from: Pat Conlon on October 15, 2012, 04:44:17 PM
:good:
keand3
Went and got my new(used) 89 forks today, and my blue dot calipers will bee shipped tomorrow :good2:
The dealer still wouldn't be live the FZR 87-88 rim/wheel would fit my new (used) forks :-)
I didn't bother trying to explain anymore,  and just said it would bee my Laos if it dint fit. :blum2: Something it will..
Hopefully he find a fzr wheel in his storage or else i just have to go with a stock 89 wheel one season :greeting:
Anyway, a new brakedisk is a must on new wheel and calipers, but there are hundreds to choose from...
298mm is what i have been recommended..
keand3
Pat,
Is the gear unit assy. the same on the 86 and 89 wheel? The parts look a like, but what i can see they have different part number..
Ken
The speedo drive will fit just fine but the '86 speedo drive is geared for the 16" 120/80 front tire
The '89 speedo drive is geared for the slightly larger 17" 120/70 tire.
It's ok to use the '86 speedo drive understanding that your speedo will read just a tad slower that your actual speed. Like less than 1%. No worries.
keand3
Quote from: Pat Conlon on October 19, 2012, 12:06:18 PM
Aha :good2:
I can live with 1%.. :-) Thanks Pat. Yours and this community's knowledge is a life saver! :-)
I know for sure that i learn something new every time i visit this forum. :i_am_so_happy:
But, If were to get a hold of an FZR wheel, Will the speedo wire fit? I might not get a complet set so i probably have to order axel etc.
Ken
Quote from: Pat Conlon on October 19, 2012, 03:05:22 PM
This is Pat quoting himself.... Not sure why, but there it is....
