What to do first?
Started by keand3, October 08, 2012, 12:34:34 PM
Quote from: fj11.5 on October 10, 2012, 05:38:55 PM
blue spots are off early yamaha r1, r6 , xjr , fjr ? fz1 ect, eBay is a good source , just don't buy the radial ones they won't bolt on to your standard forks
Just to help the many here that do not know like myself, how does one tell if the calipers are radial?
It's the mounting. Radial calipers have the mount bolts perpendicular to the front axle (tension/compression)
Conventional calipers have the mount bolts parallel to the front axle (shear)
I'll look for a picture...... Cheers laddie!
thanks mate, a pic explaines it better that I could  :good2:
Quote from: Mike Ramos on October 10, 2012, 04:53:17 PM
Right on the mark Leon.
Thank our lucky stars for Marsh & FJOwners.com and Randy from R.P.M....!
Perhaps two of the most important people who make the pleasure of owning & maintaining FJ's just that, a pleasure.
Thanks again,
Mike Ramos.
Very true Mike, and I give my respects to Randy, but honestly, if it weren't for Marsh and FJOwners.com I would be lost and neither would I have found RPM.
Without them, it would be kinda like the childrens christmas story of the island of misfit toys, all but forgotten to time, and set aside for the latest and greatest offerings.
I'm very proud to be an active part of such a great community!!
bcguide
Question
I see you can use a 88 fzr front wheel  is their any reason a 87 fzr wheel could not be used?
Same wheel, except for color...'87 is red, '88 is white.....same Yamaha part#   Strip off the paint and go..
keand3
Aha.. Thanks a lot. There's a lot of those bikes around so it shouldent be any problem to find.
Except from the radial ones, do the rest bolt on or is there other versions to?
Many thanks to you to Pat, with the picture you posted it finaly made sense  :good2:
Ken
keand3
Ok,, i choose to continue in thees thread instead if posting a new one :yes:
So the bike i now safely parked in my garage, and this winters work is scheduled.
Noticed some things when i started to look at the fairings, that they were attached with several different screws and what nuts  :greeting:
So i started searching for parts to change them with and RPM have some rubber washers, spacer and shiny oval Allen screws that would work nicely.
But i also would need to replace the retainer pins.. Not only that but also the moulded pins fitted into the rubber grommets.
Any ideas were this kind a thing might be bought? A forum search didn't give any answers (might have search differently perhaps) neither did goggle..
Ken
Look up the part# and send Randy a e-mail. He can get you oem parts.
keand3
Quote from: Pat Conlon on October 11, 2012, 12:00:51 PM
Thanks,  will do  :good2:
Ken
keand3
I have now gotten my self a new fork form a 89 FJ and will pick it up next week.
The dealer also gave me blue dot calipers from an R1 in trade for my old forks.
Since i am most likely not to use them anymore,  i agreed.
This will be my first fork removal,  so wish me luck.
I stil l only have stock front wheel and brake disc, will the new calipers work on stock disk?
They will of course be change with time also ;-)
Ken
I make oil
Semper Fi
WhiteBeard
Quote from: keand3 on October 13, 2012, 03:04:24 PM
You need a later model front wheel (89+) or even better, a 3.5'' FZR1000 wheel (87-88). The Blue Dots will not bolt onto the earlier model wheels.
Here's a great guide that will tell you all you need to know about the upgrade.
Good luck!
/Nat
Ken
When I purchased my 89, it had first gen wheels and rotors on it. I did install as set of Blue Dots and they worked fine. I eventually got a stock 89 wheel and installed the Chinese knock off Galfer rotors. Attached are some photos
Hope this helps
keand3
Quote from: WhiteBeard on October 13, 2012, 03:50:01 PM
Good luck!
/Nat
Aha, i knew there were something that i had missed.
The hunt for a new front wheel have begun. Luckely i have 6 months of winter to find one  :good2:
Ken
