FZR1000 rim with FJ12 ABS?
Started by WhiteBeard, September 27, 2012, 03:41:28 AM
WhiteBeard
I can see I'm not alone in trying to fit a new 3.5'' front right now!
I got a complete set of forks from an FJ1200 '93 on its way, as well as an 87-88 generation FZR1000 front rim.
Will the ABS forks cause a problem, or is it just plug-and-play using the 15mm axle?
Just read the other thread here were nurse was having problems fitting his XJR1200 front rim.
Thanks,
Nat
Should work fine.  ABS had no influence on the forks.
WhiteBeard
That's what I thought/hoped/remembered.
Thanks a lot David.
/Nat
