fj fuel pump
Started by Mark, September 16, 2012, 05:41:09 AM
Mark
         installed Randys new fuel pump today among other thingsd
All I ask of living is to have no chains on me( Laura Nyro)
Quote from: Mark on September 16, 2012, 05:41:09 AM
                           Installed Randy's new fuel pump today, among other things...
Those look like shiny new carbs & air filters as well. Have you gotten a chance to take it for a spin yet?
Mark
Haven't taken it for a ride yet Randy, fired it up yesterday, started fairly easily and sounded good but pumped a heap of oil on shed floor via clutch rod before I realised what was happening, going to put all clutch and brake parts in today, hopefully ride then.
[img][http://fjowners.com/gallery/3/2724_16_09_12_3_30_20.jpeg/img]
Mark
cats ok she'd floor is dirty though, would I have lst the little ball do you think,guess I'll find out shortly
Losing the ball this way seems rare, you should be fine. When the clutch slave is back on the clutch should feel normal, if the the lever feels light then you might have a problem.
yamaha fj rider
Quote from: FJmonkey on September 16, 2012, 03:53:28 PM
Is the cat ok?
Imagine that, a Monkey worrying about a cat. :crazy: :crazy: Man what is this world coming to?  :lol:  (popcorn)
Kurt
93 FJ1200
FJ 09
YZ250X I still love 2 strokes
Tenere 700
FJR1300ES
Quote from: yamaha fj rider on September 16, 2012, 11:40:19 PM
Kurt
Cats and dogs living together, it ill be anarchy!!!
yamaha fj rider
Quote from: FJmonkey on September 16, 2012, 11:45:10 PM
Kurt
:unknown: LOL LOL Glad to see you have not lost your sense of humor.
Kurt
93 FJ1200
FJ 09
Tenere 700
FJR1300ES
Mark
You were right fj monkey my ball must still be in its correct position I have a clutch after much bleeding. Got back brake sorted out as well, front tomm then hopefully ride( the whole brake and clutch system on the bike were that full of shit I'm sure it's all original inc fluid. On a different subject have any of you guys done the ride from conus to Alaska , Gunna do that soon as I can, I'm hoping it will be as good as I imagine it will be
RichBaker
Quote from: FJmonkey on September 16, 2012, 09:04:11 PM
When the ball fell out of mine, the slave piston bottomed against the cover and the lever was immobile.... Found the ball in the sump, I had the clutch apart to replace the shifter return spring.
Tennessee Squire
90 FJ1200, 03 WR450F ;8^P
Quote from: RichBaker on September 17, 2012, 07:46:07 PM
Did you lose the ball the same way, starting with the slave off?
RichBaker
Nope, the slave didn't need to come off so it stayed bolted on. Probably why the ball fell out, the spring in the slave probably pushed it out... after I got it all back together, the lever was like a rock, wouldn't move at all. Finally figured it out, after looking at an exploded view. Took the clutch cover back off and the pressure plate off... no ball, found it just under the clutch in the sump.
Tennessee Squire
Quote from: RichBaker on September 17, 2012, 07:56:22 PM
Thanks, the mystery continues, can one loose the ball by shooting it out with the push rod????
RichBaker
I think it is a larger diameter than the rod, but haven't measured them....  I don't think it'll fit thru the hole.
Tennessee Squire
