93 engine / frame rubber damper
Started by Mark, September 07, 2012, 07:10:32 AM
Mark
Hi guys was wondering if any one could tell me a bit about the special bolt that mounts on the frame and has a steel cup with a rubber plug in one end and a slotted 8/10 mm threaded stud on other, I assume it's some kind of vibration thing, is it supposed to be adjustable,it has one nut on it, buggered if I can remember how it worked when I dropped motor.many thanks Mark
All I ask of living is to have no chains on me( Laura Nyro)
flips
Hi Mark.
I'm not sure which part you mean.This diagram might help.
here's the link....
http://www.boats.net/parts/search/Yamaha/Motorcycle/1993/FJ1200AE/FRAME/parts.html
Cheers  :drinks:
Jeff P
Stay rubber side down.
Mark
Hi flips thanks for that it's part no 23/24/25 . Looks like it just bolts in there tight, I was thinking it was adjustable for some reason, not enough alcahol to lube the brain cells probably, cheers
