fork oil level?
Started by Antonn3, September 02, 2012, 01:07:16 AM
Antonn3
Ok this might be a simple question to some...but when checking the fork level...is the fork checked with it being held straight up or angled as if it was mounted in the triple tree?  On some videos I see the oil  level checked out of bike, forks being held straight up and others where it is checked with them on the bike?  Is there enough of a difference for it to matter which way you check?
Other then fork level and oil type, I could not find that info.
Thanks
Tony
FJSpringy
for me its out of the bike, straight up, compressed fork, spring out, measure from the top.
I have kleptomania,
but when it gets bad,
I take something for it.
92 FJ1200
Yes, the proper way is as Springy says, but the difference in distance can be no more than 2-3mm if you measure while they are in the triple clamps.
If you're careful and measure at the midline of the tube, the measuremens will be the same on or off the bike.
My procedure is to set the oil height straight up when I've rebuilt the forks or had them off the bike, but I wouldn't bother taking the legs out of the triples if I was only making an adjustment in oil height or changing the setting on my emulator valves.
yamaha fj rider
Quote from: FJSpringy on September 02, 2012, 03:05:46 AM
+1 Could not say it better.
Kurt
93 FJ1200
FJ 09
YZ250X I still love 2 strokes
Tenere 700
FJR1300ES
oldktmdude
  Keep a record of the amount of oil you used, to make it quicker and easier next time.  Regards,  Pete.
1985 FJ1100 x2 (1 sold)
2009 TDM 900
1979 Kawasaki Z650 (sold)
2001 KTM 520 exc (sold)
2004 GasGas Ec300
1981 Honda CB 900 F (sold)
