Chain Adjuster Right Side Loose.
Started by David Allaband, August 19, 2012, 06:23:29 PM
David Allaband
Hi all. When I adjust the slack on my chain I can't get the right side tight. I can tighten the two nuts on each other, but they don't press the back plate into the swing arm. That back plate still moves just a little. I tried kicking the back tire, I tried tapping on the right side of the axle with a wood block and hammer. I can make it go tight, but it won't stay tight while I snug up the adjusters. Am I doing something wrong? I ride the bike and it seems fine, no squirlyness in turns or anything.
Thanks for any help!
Dave.
Sometimes the fear won't go away, so you'll have to do it afraid.
Los Angeles, CA
1/3 1987 - 1/3 1989 - 1/3 1993 FJ1200
oldktmdude
  Place a piece of timber  between the bottom of the rear sprocket and the chain. Turn the rear wheel in a forward direction to apply pressure to the adjusters. Hold it in that position while you tighten the axle nut.   Regards Pete.
1985 FJ1100 x2 (1 sold)
2009 TDM 900
1979 Kawasaki Z650 (sold)
2001 KTM 520 exc (sold)
2004 GasGas Ec300
1981 Honda CB 900 F (sold)
David Allaband
That's it! That's the part I forgot, jam up the chain. Thanks Pete!
Los Angeles, CA
