Starter replacement
Started by Mike 86 in San Dimas, August 19, 2012, 05:00:59 PM
So I am attempting starter replacement and am hoping others who have done this will chime in. Basically simple task  :dash2: It's loose with power cable disconnected and according to Clymers I can remove it by pulling through left side. But I cant seem get it through. Friken close though. Although repair manual does not say so I about ready to remove the left side crankcase cover, which means clutch slave too. Is this necessary. If I remove the clutch slave, will I need to drain fluid and all the fun that along with that. I cant remember, I think so.
Thanks,
Mike
Clutch slave can be removed without re-bleeding, just don't squeeze the clutch with the slave off.
Thanks Dan,I needed to be reassured about that.
Mike
oldktmdude
  Do not test the new starter with the clutch slave removed!  Regards, Pete.
1985 FJ1100 x2 (1 sold)
2009 TDM 900
1979 Kawasaki Z650 (sold)
2001 KTM 520 exc (sold)
2004 GasGas Ec300
1981 Honda CB 900 F (sold)
bigbore2
On my 84, I need to loosen up the banjo bolt connected to the slave and rotate it out some to get to the bolt nearest it. I  just rotate out and then retighten bolt enough to prevent leaking while making repair.
Are you getting starter rebuilt or buying new one?  Starting engine with slave removed will blow out the rod slave pushes on, from what I read earlier.
I bought a new one, (from Randy of course) so will have a starter (that was working) for someone they may want it. My starter is ready for rebuild and I am tired of intermitten starting issues. I understand the new starter to be a lot better. I cant get the damn thing to clear by a fraction, no mater how much I cuss. I will be back to it soon.
Mike
I took of my alternator, much less work than the cover.
no airbox , starter comes out easily , just another benefit of air pods
Thanks for the replies. Job done. I ended up taking the cover off. Easy then.
Mike
