17" rear wheel conversion
Started by craigslist1340, August 09, 2012, 09:52:31 PM
craigslist1340
Quote from: chocker on August 13, 2012, 04:04:11 PM
What year and model brake stay are you using?
Mark
A GSXR 1100. years 86-92. They're all over Ebay.(Item number: 251011690084)for example. They have a sperical joint on the one end which you can bolt tight to the footpeg and it will still pivot.It has an 8mm hole on both end so no drilling required. I think I used 8mm/1.25/35mm bolt e caliper end, and 8mm/1.25/70mm on the footpeg hole, both with s.s. lock nuts.(Bolt Depot)
John.
1985 FJ1100, 1989 FJ1200, 1984 FJ1100, 69-70 Honda z50's times 3,  1973 Honda CT70.
tlpoe222
Hi, i am quite new to all this and had a question about this conversion, the gsxr750 slingshot rear wheel has bearings with an internal diameter of 14mm yet the fj1200 rear wheel bearings have an internal diameter of 15mm
So how is it possible to use the FJ spindle on this conversion?? Im not a moaner i was just curious
Egg
Travis398
You're reading the numbers wrong, the FJ has a 20mm axle and the bearing is 15mm wide
craigslist1340
Quote from: tlpoe222 on August 27, 2012, 03:43:59 PM
Egg
s
What Travis said. Gsxr and Fj's_have 20mm bearings and axles .
tlpoe222
Aaaaaaaaaaahhh..... Yes, sorry guys, i am megatronicly rubbish,  :wacko3:
And i bought a slingshot gsxr750 wheel with a good tire, caliper bracket, spindle and all spacers delivered for £32, all i need is some washers and a caliper
Is it possible to use my standard caliper and mount bracket until i can find a gsxr caliper?
Quote from: tlpoe222 on August 29, 2012, 09:22:11 AM
Of course, PROVIDED it fits within the swingarm and positions the caliper centered over the disk with full sweep of the pad surface.  You'll have to be the one to check or adjust these items as its not a 'standard' fitment.
IF it does fit properly (or is able to be adjusted easily) you may not want to bother getting the GSXR caliper.
jscgdunn
Quote from: craigslist1340 on August 13, 2012, 08:43:39 PM
Mark
John.
Hi craigslist,
Just to be clear the whell also is from a GSXR 1100 86-92?
Thanks ,
Jeff
90 FJ 1200 (Son # 2), Stock
craigslist1340
I gave the wrong years, its 88-92 not 86. but I think wheels up to 98 will work. 1100 or 750 wheels. Depends if you want straight spokes or curved spokes. Get one with the hub and rotor so you don't have to piece it together. I got a 95 1100 complete, and waited for one that was cheapest at the time. I wasn't in a hurry and price was my objective.
John
Quote from: jscgdunn on September 10, 2012, 09:09:08 PM
Mark
John.
Hi craigslist,
Thanks ,
Jeff
chocker
Hi,
I'm in the process of getting the parts. I have a 1992 GSXR 1100 rear caliper, sprocket , cush drive, axle spacers and slingshot. I am looking for the wheel. I may change the sprocket. So, for a GSXR 750 wheel, it will work with up to 1998? I ask this because in the FJ GSXR rear wheel conversions by Kit Kat Black it states to use the following:
88-89 GSXR750 & 1989 1100: 4-1/2" 17"
90-92 GSXR750 or 1100 5-1/2"x17"
93-95 GSXR750 5-1/2" x 17"
93-98 GSXR1100 5-1/2" x 17"
Are there other years and models that may work as well. Maybe someone has had some experience with other models.
Mark
craigslist1340
Hello, use one of the wheels you have listed and you won't have any problems. Make sure the spacer is between the bearings. The wheel I bought  someone didn't put it back when they changed one bearing.
John
chocker
Hi,
I found a 1992 GSXR 600 WN rim that is a 17" X 5.5. It has the six sections for the cush drive and not five. This bike was only made for the 92-93 model years. Would this fit as well. I ask this because it is a great price and I might be able to pick it up instead of paying shipping.
Mark
Antonn3
Hello cocker, giantkiller might be able to help you as I think he has a similar wheel.
I purchased a sprocket from him as it would not fit his wheel. he said the following...
" I found out that the 92 GSXR 750 wheel I got from the breaker is actually a 92 GSXR600 wheel. The 600 has 5 sprocket bolts and the 750 and 1100 have 6 sprocket bolt"
Hope that helps.
Tony
chocker
Yeah but I saw a picture of the wheel and it had six sprocket bolts and not five as I have previously stated.
Mark
chocker
Here is the Ebay item # 200821539449
Mark
fj11.5
looks like the same cush drive as the 89 ect 1100 rims, , that's a bargain price , buy it,, buyyyy itttt  :good2:
84 Fj1100  effie , with mods
