Front End Follies
Started by motohorseman, August 06, 2012, 02:06:21 PM
motohorseman
I bought a nice new set of Avon's a while back, and always noticed a little bit of a pull to one side when stopping, I thought it might be a warped rotor, never gave it much thought.
I've notice that at certain speeds, the front end shakes if you let off the handlebars - Many motorcycles just have this trait, and I have told the owner to not take their flipping hands off the handlebars.
No worries, nice new tire - then today, I noticed something strange, WTF! I have a nearly bald spot on the tire - one stop, the rest of the tire is like new, or darn good to say the least.
I noticed it first in the profile - instead of nice and round like the other 90% of the tire, this section is "a concern".
The right side -
I had a closer look, worn to the tread wear indicator and beyond - in this one section of the tire!
I whole little section is worn out - Again, see the right side of the tire
The rest of the tire is like new - with one exception, on the other side there is also a worn spot, although not nearly as bad.
Here is another picture showing the total destruction of the profile, heck, I'm not sure I want to ride on it any more.
I need a tire, that is a given. Steering head bearings feel good, I'm thinking I need to replace the fork oil or ?
Any thoughts, ideas, I want to order parts but in this economy, I need to be as frugal as possible.
I do not feel the rotor pulsing in the hand brake lever, usually I can feel that, and I am not sure that would cause this wear.
Psychic mechanics, your help is appreciated!
soundmindryan
Quote from: motohorseman on August 06, 2012, 02:06:21 PM
How many miles? I had an Avon Storm 2 ST do something similar. Noticed it first by viewing the profile. I chocked it up to slight underinflation although after I began checking pressure more often, the tire still seemed to continue to deteriorate rather quickly. I think, without checking my records, that I got about 12k out of it. Replaced with Michelin Pilot Road 2 and it's wearing much better. My thoughts are it's the tire and not necessarily anything with the bike. But come to think of it, I did a fork rebuild about 4k miles ago but already had probably at least 2k on the tire before doing that. Had a motorcycle mechanic tell me the V-rated tires and above are very sensitive to inflation pressures.
Ryan McCollum
Tulsa, OK
'89 FJ1200 White & Silver
'90 Yamaha Venture Royale
"I visited a scientist who had a helmet with magnetic fields controlled by computer sequences that could profoundly affect your mood and your perceptions."
-Douglas Trumbull
motohorseman
Quote from: soundmindryan on August 06, 2012, 02:38:29 PM
Not that many miles, I'm guessing but I'd say less than 5000, probably for sure less than 5000. I always keep my pressure at the higher end of the scale.
My memory seems to think I've had issues with a Avon before......
I tended to wear out my Avon front evenly on both sides. Not sure how you are doing this. Is the other tire doing the same?
http://www.fjowners.com/index.php?topic=287.msg2088#msg2088
fj11.5
maybe the shape of the road crown   :wacko3:
84 Fj1100  effie , with mods
markmartin
Just a thought. Do you have the tires balanced when they are mounted?
FJ Flyer
Avons are known for spotty quality control.  I've had good luck with their rear tires, but its been hit or miss with the fronts.  May be a monday or friday set of tires.
Chris P.
'16 FJR1300ES
'87 FJ1200
'76 DT250
Wear your gear.
Contact Avon and see  if they will do anything for you..... there is nothing that a motorcycle/rider can do to make a tire look like that.
First and foremost....tires are supposed to be round.  :good2:
What Frank said! That tire looks like you are riding around r/h corners continuously. Get onto Avon - send them your photos. There is for sure something amiss with that tire.
Wow... I find it hard to blame the tire. But.. I would check everything with a fine tooth comb. Check your rear tire alinement with the front. Somewhere I read where they were using a couple of cheap laser levels to check the rear to front tire alinement. There is a lot that can go wrong between the rear and front end. Check head bearings, and forks of course.  It helps to make as many right as left hand turns, hee, hee :). Hope you locate the problem. Wish I knew more to contribute.
motohorseman
Quote from: markmartin on August 06, 2012, 06:53:24 PM
I mount and balance my own tires - have for the past decade or so.....
This is a new problem to me. After working at 2 dealerships, I want to blame the tire, but.....
As soon as I can make the time, I'll start checking the bike.
One spot, I never would of noticed if it was not in the exact right position, glad I did, I tend to ride hard, and a blow front is the worst of the worst IMO....
I've had a tire do that.  One fork leg was dry, one was filled with sludge.  Happened to a metzler, I think.
BSI
I'm with Frank and Harvey, I can't figure how anything else other than the tire or maybe it's relationship with the rim could cause that...if there's some evil forces coming from bike that creates issues at the contact point of tire and the road, wouldn't it affect the tire's contact 360 degrees instead of only when that 10% section came around?...have you made sure the tire bead is evenly set all the way around the rim?...good luck, I hope Avon get's you a new tire
92' FJ1200
86' FJ1200
86' FJ1200 - just bought-not started in 2 yrs
04' Suzuki DRZ 400S - cornering on knobbies
76' Husky WR250 - bought in 81', needs lots of TLC
FJSpringy
I had a PR2 do that years ago, was just a crap tyre, all my other PR2's have been fine.
I have kleptomania,
but when it gets bad,
I take something for it.
92 FJ1200
After taking a second look at your tires and considering my personal experience with Avon's I think I can offer some additional advice. You really need to hit the corners more. I tend to leave some life on the top part of the tire. For some reason they put more tread there making it the thicker part of the tire. But I don't commute with my FJ, I find the shortest route to the twisty roads and enjoy.
So, if you can find a way to stay off the straight roads then you might never have discovered this current and bizarre wear problem you are having. Ride around the problem by having more fun leaned over. Just remember, advice is is not always worth what you paid for it, and free advice is....well possibly worth less that what you paid, even if came from a monkey dressed up in a Red Power Ranger suit.... :drinks:
