brake bleeding problem
Started by 427 chevelle, August 05, 2012, 10:42:11 AM
427 chevelle
hi all,i am having a problem bleeding the rear caliper of my 85 that i recently rebuilt.i cant get the fluid from the resovoir to the claiper,  i have tried depressing the brake lever and a vacuum bleeding tool.all i get is air.getting a little perplexed here.the brakes are original no mods,any ideas would be greatly appreciated
When I use my Mity Vac to pull a vacuum at the caliper, some Teflon tape on the brake bleeder nipples helps keep the air from drawing in around the loose threads.
Double check your crush washers. Use new washers or apply some heat to soften your old washers before re-use.
Did you get the seals in correctly on your rebuild?  Hope this helps.
427 chevelle
ill try that ,thanks,i think the master cylinder might be the culprit though
SkyFive
Another little trick is to attach a length of vacum hose to the bleeder, take the cap off the resavoir and open the bleeder until fluid runs out. It will speed up the process.
Yamifj1200
Quote from: SkyFive on August 05, 2012, 11:51:55 AM
+1 if you put a open half hitch in the line and put the other end into a small can, gravity will beed the line in very little time. I was able to rebuild Dave's clutch slave cylinder and bleed in less than 45 minutes.
Eric M
427 chevelle
ok,i have the master cylinder out and it appears to be siezed,how would i get it apart??
in the  plunger end where the lever pushes , should be a circlip  under the rubber cover bugger to get to , but circlip pliers help
427 chevelle
see it,and got it apart,thanks
dont forget to clean the return port, in the master, or the brakes stay on  :wacko3:
