Not starting after removing fairing
Started by rfmstan, July 22, 2012, 07:51:35 AM
Oil light lights up everytime I try to start the bike but no start up ???
No start up
0 (0%)
Oil warning light
0 (0%)
Total Members Voted: 0
rfmstan
Hi all
Could anyone one help me in this matter, I removed the fairing but now when I go to start the bike I get the oil warning light light up and no engine start up. ???? Any idears peeps
most likely a dodgy wire going to the starter relay behind the fairing on the left side, its the multi function relay  , large one guessing its the blue / white wires giving trouble, , try putting a small jumper wire from one to the other at the relay plug, , , can also turn the ignition on , the blue and white  wire from the starter relay under the seat, take the 2 wires apare at the connection , use a short wire pushed into the female side of the plug and touch it onto the negative battery terminal, bike should start :good2:
axiom-r
I thought there was a component of the ignition system in the nose fairing that had to be plugged in to run the bike......  I know I cannot run my 92 with the nose off.
tim
ahhhhh theyre just could be, im only talking from 84 1100 weird wire experiance, not these new fangle machines  :dash2:  :biggrin:
FJSpringy
nothing specific in the fairing, I was running my 92 sans fairing for a few weeks while working on it. I would suspect you have dislodged a connection or "activated" a bad connection somewhere.
I have kleptomania,
but when it gets bad,
I take something for it.
92 FJ1200
rfmstan
Thanks for all your replys  :i_am_so_happy: . i will give them a try the weekend, thank u all agian
