pistons missing
Started by CanDman, July 21, 2012, 01:17:58 PM
weymouth399
OK, I'm wrong :shok: 89 and later. Your CDI box is the same as mine, 84-87 so don't threat that yet. But you may have to jet a bit different on topend for that big.  :yahoo: And make sure your Dyna coils are early model ones, there is a difference in ohms between them.
Bob W
84 FJ 1100
86 FJ1200
89 FJ1200
5  FJ POWERED race cars
76 LB80 Chappy
93 KX500 ice for sale
00 KX500 ice/dirt
04 KDX220 dirt for sale
04 KX500 ice
08 KLX450 ice/road
72 CT90x2 for sale
CanDman
Quote from: Pat Conlon on July 22, 2012, 10:49:55 PM
Kev, you should be fine with your oem ignitor box.
You do know that proper fuel line routing is important with the gravity fed bikes, right?
If not routed correctly, the line will pinch when the bike heats up.
The single fuel line (from the petcock) runs *under* the 2 branch lines (which goes to the carbs)
Pat
thx Pat
CanDman
ok....I am looking at the coils....and they are high output dyna coils...and the spark plug wires were replaced......now earlier you suggested I should go back to stock coils.....but your last post implies keeping the dyna coils........sorry bob......which door am I picking door #1.....the dyna coils....or door #2....buying a set of brand new 86 stock ignition coils....and putting them in....just want to be sure......Pat also weighed in....hearing more and more about the fuel hose routing......also should I have the carbs rejetted at the top???
CanDman
paulfj03
Yeh.... if you were closer I would have what you need... bummer.... no time to mail them either.... :negative:
If you want to drive here and pick them up :pardon: I could scare some up.   :crazy:
weymouth399
Seeing that you have no time. First try to get what you have working, check all wires and connections.
Unless you know it's not going to work and/or you can get the factory ones in time. Use factory if poss.
Yes check hose routing, and if stock style hose, get FI rubber hose if not, that cured my prob there. Kinked when got hot, and improper routing.
Whats in it for jets now? Stk? whos kit?
Bob W
84 FJ 1100
86 FJ1200
89 FJ1200
76 LB80 Chappy
00 KX500 ice/dirt
04 KX500 ice
08 KLX450 ice/road
72 CT90x2 for sale
CanDman
Quote from: weymouth399 on July 22, 2012, 11:19:21 PM
Bob W
which kit would you recommend?
CanDman
Quote from: paulfj03 on July 22, 2012, 11:18:46 PM
tomorrow is supposed to rain...I can jump in the truck and drive over....its only 2 hrs......are you home tomorrow Paul?
Kev
weymouth399
Quote from: CanDman on July 22, 2012, 11:23:10 PM
Bob W
That my friend is a loaded question just like who's oil to use. I use HSR or make my own up and use his needles. Most will work try to get ones that only use factory mikuni jets.
Bob W
84 FJ 1100
86 FJ1200
89 FJ1200
76 LB80 Chappy
00 KX500 ice/dirt
04 KX500 ice
08 KLX450 ice/road
72 CT90x2 for sale
paulfj03
Quote from: CanDman on July 22, 2012, 11:24:42 PM
Kev
not during the day ... but I can take the parts with me to work  and meet you in Trenton...(?)
so I want to bring Oem coils, wires ?  maybe I could freshen up the wires/connections...the handiest available are off an 86.... is that ok? (BoBW?) I will look for 84/85 as well.... but I will try to get OEM for sure....   let me know....
CanDman
do you have any for sale? if so.....I will buy them........overnight courier them if you have...and I will wire you the money...or...tell me what you want for them and I can wire you the money first along with the cost for overnight shipping
CanDman
weymouth399
Quote from: paulfj03 on July 22, 2012, 11:30:50 PM
Kev
Yes that will work. 84-87
Bob W
84 FJ 1100
86 FJ1200
89 FJ1200
76 LB80 Chappy
00 KX500 ice/dirt
04 KX500 ice
08 KLX450 ice/road
72 CT90x2 for sale
CanDman
Kev
for sure....I will come to trenton.........
CanDman
bob....do you have a jetting kit for sale ?
weymouth399
Yes I do, in stk.
Bob W
84 FJ 1100
86 FJ1200
89 FJ1200
76 LB80 Chappy
00 KX500 ice/dirt
04 KX500 ice
08 KLX450 ice/road
72 CT90x2 for sale
paulfj03
Thx Bob.... i will dig them up..... they are used but worked fine .... :good2:
kev,
If you want to pick them up thats fine(trenton) , ... or I can ship them....I assume tomorrow....we'll worry about buying them later..... I still have to eat at your BBQ!!!! :flag_of_truce: :rofl:
I will let you know when I have them in my hand.... heading out to look.....
