Peg Vibration
Started by Sabre093, June 30, 2012, 06:48:22 PM
Sabre093
I've noticed today that foot pegs buzz something awfull at 110-120 kms,read some posts on some thoughts but still sending it out to FJ universe,what do ya think...I'm planning to have rear wheel bearings and cush drive inspected Tues...other than that i draw a blank...
2009 FJR 1300
1992 FJ 1200
1987 FJ 1200 Sold
1986 FJ 1200 Sold
1985 Venture Royale
1976 GoldWing
1986 FZ 750
1986 GPZ 900
1984 Honda Nighthawk S 750
1982 Honda Nighthawk 450
McKilla Guerilla
That is raw power being delivered from the bike to your body.  :lol:
Id like an answer on this too although I always thought it was just nature of the beast.
Good decisions come from experience, Experience comes from bad decisions.
Sync your carbs, otherwise rubber mount your engine or replace your mounts. Maybe it is your Kookaloo talking to you?
McKilla Guerilla
I was leaning toward engine mounts too but it hasn't got quite so aggravating to me just yet
put your heels back on the rests and just keep your toes on the pegs.... the pegs are rubber mounted and will absorb a lot of vibration.  Maybe your rubbers are perished a bit? I dont recall if they are replaceable or not.
sync'ing the carbs also does wonders for vibration issues on early models... what year is your FJ ?
Kookaloo!
Sabre093
I'm driving a 86 and this vibration was not this intense when I first got it and bike was not run much before I got it,so I'm trying to cover several areas when it go's in Tues
2009 FJR 1300
1992 FJ 1200
1987 FJ 1200 Sold
1986 FJ 1200 Sold
1985 Venture Royale
1976 GoldWing
1986 FZ 750
1986 GPZ 900
JCainFJ
 Check the bolts that attach the frame down tubes. The two rear bolts can come loose and even brake. You will have to remove the "bracket", the alloy castings that support the pasanger pegs and exhaust system. Every FJ I've worked on has had this problem. I think it would be smart to drill and safety wire these bolts.
Sabre093
I checked the chain tension,was loose so I adjusted it and and went for a ride and was better,I left what I thought as proper tension,my buddy said my chain was moving quite a bit while under load,so I'm  adding this to to-do list on Tues at shop,going to replace chain and front sprocket and have wheel bearings checked, if vibration persist I'll start a new plan of action,crossing those off list and move on to what it could be next
2009 FJR 1300
1992 FJ 1200
1987 FJ 1200 Sold
1986 FJ 1200 Sold
1985 Venture Royale
1976 GoldWing
1986 FZ 750
1986 GPZ 900
Sabre093
I think we have problem solved...Chain was pooched!First time i've smoked a chain,I did almost 200 passes on my FZ 750 never had a problem,told mech to put a good one on as FJ's feast on them,and thanks for heads up on clutch work ...I got a FJR spring instead of FJ one going in,and I'll get the oil adapter kit from Randy for next oil job...things are coming around  :good2:
2009 FJR 1300
1992 FJ 1200
1987 FJ 1200 Sold
1986 FJ 1200 Sold
1985 Venture Royale
1976 GoldWing
1986 FZ 750
1986 GPZ 900
