krauser luggage
Started by loki, June 27, 2012, 03:30:32 PM
loki
hey guys i need some help! just put the luggage on that i got with the fj and its a bit wobbly!!! any wee tricks to to get it more solid and secure...
dream as if you'll live forever live as if you'll die today
whats wobbly?  the luggage in the mounts or the mounts themselves?
loki
Quote from: racerman_27410 on June 27, 2012, 04:22:34 PM
the luggage in the mounts bud
Yamifj1200
If I recall correctly Krauser bags mount very much like the Hepco becker bags do. A plastic lug that connects into a portion of the pipe rack and a latch assembly on the other end of the bag that is suppose to pull the side case into the frame.  If the bags are moving make sure the plastic lug is located properly into the pipe frame and the latch assembly pulls the bag in tight to the frame on the opposite end of the bag.
On my Hepco Becker bags the latch actually pulls the side case in tight to the frame.
Eric M
Quote from: Yamifj1200 on June 28, 2012, 06:08:47 PM
Eric M
this...... + i believe the latch plate is also adjustable to add more tension.
Kookaloo!
vengi
Unfortunately, I still do not have this set in my possession, but I want to buy.
I think a normal spring washer to replace the pad to reduce vibration.
Oraginal coast instead of putting self-closing coast.
System performance of Hungarian Krauser K2 FJ Club forum.
nick name: FJgyori
http://fjforum.atw.hu/
javascript:void(0);
vengi
Quote from: vengi on July 31, 2012, 07:29:41 AM
Direct link:
http://kepfeltoltes.hu/120731/SDC10101_www.kepfeltoltes.hu_.jpg
