Clutch m/c list, is there one? If so can you point me towards it!
Started by nurse, June 21, 2012, 02:48:30 AM
Derek Young
Quote from: nurse on June 24, 2012, 05:06:13 AM
The fluid itself is light brown but after a good run seems to have what appears to be a mucky rust like staining to it. It collects and drips from the lower housing. But looking at the paint stripping as seen in the pic I'm guessing it is running from above therefore I guessed slave cylinder
If it is leaking from the clutch slave you should fix it soon.  That brake fluid will eventually destroy your paint and the plastic lower cowl.  Its the devil's piss, quite corrosive to paint and plastic.
1986 FJ1200 (R.I.P.)
Nanaimo, British Columbia
nurse
Well the leak is fixed!  The fjr clutch master is fitted, bled, wired in and hot to trot.  Replaced the hoses with braided all the way through! Had a run out for half hour to make sure all was good. And all was very good!  It now feels progressive, accurate and feeding in power is responsive and accurate.  Gear changes are now slick and fast!  I was always quite good at slow speed manoeuvres on heavy bikes, but with Babs she always felt a little rustic/agricultural when trying to balance throttle, rear brake and clutch.  Not anymore!  It is so smooth. I would argue that as far as prioritising mods go this has got to be up there with blue dots as one of the first three to be done!
:good2: :yahoo: :i_am_so_happy: :biggrin:
Sabre093
Quote from: flips on June 21, 2012, 04:48:37 PM
Quote from: nurse on June 21, 2012, 04:07:30 PM
Forgot to ask with the fjr clutch mc is there any particular year to look for or avoid?
Hi nurse.
I don't know about which models to avoid,but I used 2001 fjr1300 brake & clutch mc's on my 86 with good results.Nice adjustable levers too!
Cheers  :drinks:
Jeff P
How did you get GPS set up like that,real nice!
2009 FJR 1300
1992 FJ 1200
1987 FJ 1200 Sold
1986 FJ 1200 Sold
1985 Venture Royale
1976 GoldWing
1986 FZ 750
1986 GPZ 900
1984 Honda Nighthawk S 750
1982 Honda Nighthawk 450
