Air Filter Oil Options?
Started by David Allaband, May 24, 2012, 08:12:46 PM
David Allaband
Hi! I have Uni pod filters I got from RPM. I got gas on them so I want to reoil them but I can't find the oil that came with them. I still have half a can of spray oil from K&N. So my question is, can I use K&N air filter oil on Uni pod air filters?
Thanks!
Sometimes the fear won't go away, so you'll have to do it afraid.
Los Angeles, CA
1/3 1987 - 1/3 1989 - 1/3 1993 FJ1200
NO!   Foam filter oil only, the K&N stuff is too thin, it'll drain off the filter.
just wondering if rc air filter oil could be used, its nice and tacky same as normal filter oil   ,I have a bit left over ? :good2:
If it was for a foam filter, it'll work....
thanks, ill give it a try once randy,s filters show up,
yamaha fj rider
Any good foam filter oil will work. Any local bike shop should stock it. I like the PJ1 spray on filter oil and cleaner works great! Just don't motor oil if some one tells you to! Hope this helps.
Kurt
93 FJ1200
FJ 09
YZ250X I still love 2 strokes
Tenere 700
FJR1300ES
