UK question: Randys spin oil filter adaptor
Started by ELIMINATOR, May 19, 2012, 08:08:23 AM
ELIMINATOR
BMW 1150GS
Moto Guzzi California 3
terryk
Randy sells a couple of different ones. Go with the Wix, better filter.
ELIMINATOR
I'm not sure if the filters are available in England.
BMW 1150GS
ELIMINATOR
Hardly want to buy a filter from the States every time! The Bosch one over here is $28!!!!!!!!!!!!!!
That was why I was hoping to get a UK answer :pardon:
BMW 1150GS
FJ111200
Ay up Eliminator, i'm on the XJR forum aswell, and i did asearch and came up with this for you.
http://www.yamahaxjrownersclub.com/phpBB3/viewtopic.php?f=90&t=45863&p=438466&hilit=SPIN+ON+OIL+FILTER#p438466
There is also a chrome filter i believe form K&N, the K&N303C.  Randy goes on there aswell.  I go by a different name on there, and i'm not telling :hi:
HTH.
jwh
when i got mine i took it to halfords and checked lots of filters and ended up with a fiat one, a sinequecento one i think but will check it later on and see, crash bars do not get in the way at all.
jwh
the one i use is an hof287 from halfords, they had lots that fitted but i liked the size and shape of that one best, works fine for me.
I'm using a ryco short filter z411 dousnt come past the generator/
Quote from: fj11.5 on May 19, 2012, 04:40:59 PM
If you don't have engine guards (not CRASH bars) then keep the filter short. Otherwise even a gentle low side on the Left can shear off the filter. No limping home or riding till a new one goes on. My first filter (a Wix) stuck out far enough that it would make contact. Once I saw that potential I went with a shorter Amsoil filter with anti-drain back feature like the Wix. I still want some engine guards.
ELIMINATOR
I like your positive thinking, "engine guards" :good2:
BMW 1150GS
The installation instructions will have several part numbers for US and international filters you can use for x-ref.
ELIMINATOR
BMW 1150GS
WhiteBeard
Quote from: ELIMINATOR on May 19, 2012, 06:47:58 PM
In your case, I would call them "auxiliary light brackets".
:yes:
ELIMINATOR
BMW 1150GS
