rear sprocket
Started by fj1200owl, May 19, 2012, 02:22:12 AM
fj1200owl
I've just replaced the 16" rear wheel for a 17" YZF 600 thundercatwith a 170*60*17 could anyone give mealittle advise on the tooth requirement for   the rear sprocket to maintain the same gearing.
Thanks Mike :flag_of_truce:
markmartin
Search function, top of the Home page will provide you with more information.  This should get you started.
http://www.fjowners.com/index.php?topic=5355.msg46627#msg46627
You've functionally added one to the back.
If you had 17/40, go 17/39 to retain the same gearing.  One tooth though, really?  Don't bother, it's close enough.
93fj1200
Hi, what is involved in getting the thundercat wheel to work for you?
Travis398
Quote from: andyb on May 19, 2012, 06:34:56 AM
That's what I would say, but I used a 180 YMMV
fj1200owl
Quote from: 93fj1200 on May 19, 2012, 07:41:53 AM
8mm off the lefthand spacer,8mm off the FJ brake mount and 3mm off the sprocket carrier face,took 30minutes in the machineshop,very easy mod,looks good,feels good on the road too.
Mike
fj1200owl
had 17/41 will go 17/41 just to pep the delivery up and see if  i like it if not i'll  go 17/40
Mike
http://www.fjowners.com/index.php?topic=1567.0
There are other swaps that also work, depending on your level of mechanical ability and what's available for you.
