oil drain plug
Started by bigbore2, April 09, 2012, 05:35:45 PM
bigbore2
jusrt going thru everything before getting my "new" bike back on the road, drained the oil and was wondering if there is a washer that goes on the drain plug.  I looked up in the Yamaha OEM parts diagram but I could not even find the drain plug on the crankcase pic. And a search for oil drain plug turned up nothing.  My Honda Civic uses an aluminum crush washer.
WhiteBeard
bigbore2
The FJ use a similar aluminum washer to the Honda.  IIRC, the washer is a 14mm ID.  I got some a O'Reilly Auto.  I actually prefer the aluminum to Randy's offering (Sorry Randy).
maybe the washer is stuck on the sump still (popcorn)
bigbore2
No washer on sump or drainplug, just a lack of .... from previous owner.
I'm still a huge fan of using sparkplug washers.  Just don't reuse them.
Quote from: andyb on April 13, 2012, 08:02:05 AM
I've been using them for over 25 years (not just on the FJ) and they work great, better than anything else I've tried...  I still have the original, un-needing of repair, oil pan, too.
I guess I need to count up the oil changes on my '85.  It's been MANY over the years.  I'm still using the ORIGINAL washer!
I have, however, chosen to ignore the instructions in my GYSM that wants me to torque the bolt to 350 ft-lb (yikes!)
Quote from: SlowOldGuy on April 13, 2012, 10:09:04 AM
David-
Do you re-anneal the washer before you put it back in, or just slap it back in?
Do tell?
Thanks,
Dan,
It appears to have permanently bonded itself to the drain plug.  I figure from all the oil changes over the years that it has lapped a matched seal against the case and adding a new washer at this point will destroy this unique seal surface that has developed between the parts.  :-)
Why mess with success?  I never liked the "feel" of a crush washer (like on spark plugs), it always feels like the threads are stripping as the washer crushes down.  Gives me the creeps!
I also don't anneal brake line washers.   I use 600 grit to re-surface them to a nice shiny and flat finish, then tighten them down.  So far it has worked every time (even though I stocked up on a good supply of copper washers about 20 years ago, not that it's an indication of OCD or anything like that).    :-)
bigbore2
Fj11.5- You called it.  I am a doofus.  When I took off the oil drain plug bolt it looked like it had a shoulder on it, hence no washer in site.  Later with more scrutiny, I realized the "shoulder" was the old washer firmly pressed onto the plug, that took some effort to remove with tools.  I picked up some 14mm washers to use and will be able to use them on my car also, thanx to simi-ed.
Slowoldguy, I know the feeling of threads stripping too,
but on a steel/steel interface that would be unlikely, one would just have to trust the steel. I have felt that on steel/aluminum and steel/ magnesium and its not a good feeling.  I am going to try your 600 grit method for my brakes cause I have to go thru the whole system there.
Dan how are you re-annealing these washers?  That is for aluminum only?
lucky guess mate,, glad you worked it out    , i didnt like the oem plug or washer so bought a dimple brand plug, better size hex , and uses two washers
Quote from: bigbore2 on April 18, 2012, 06:10:14 PM
The washers are aluminum.  Re-annealing, from what I've read, involves heating and quenching.
Me, I've never done it, I, unlike David, replace my washers each and every time I change the oil.
bigbore2
Want to keep my plug for the nifty little magnet.  Heating and quenching is easy enough if thats all it takes for annealing.  I always thought heating and quenching metal makes it harder,stronger and more brittle?  Yes/ no?
