Windage tray availability
Started by JMR, December 15, 2011, 04:56:29 PM
JMR
 Are there any effective windage trays out there for the 1200? I have seen one (in a pic) in the past.
JMR
OK....I emailed HSR. Is that a dirty word around here?
I think you lost them at "windage trays".  :mail1:
Sorry, I missed the first post...
I have never seen one.
HSR makes an oil pan baffle to try and "control" oil flow and slosh away from the pick-up screen but that is all he has.
JMR
Quote from: racerrad8 on December 16, 2011, 08:44:24 PM
That is exactly what I'm looking for Randy. "Windage Tray" is really not the correct term but it is generic. Oil control at the pick up level is what I'm talking about. The beauty of the old CB750's is the factory dry sump system. The CB is my bread and butter to the point I make heavily finned alloy cylinders for 1000cc displacement with Nikasil bores. They are not the old RC blocks.
JMR
HSR is sending one out. I am surprised more guys with street bikes haven't experienced the oil movement probelem I have encountered.
Quote from: JMR on December 21, 2011, 07:07:40 AM
we have encountered the oil movement thing but personally i dont consider it a "problem"
The oil level light coming on is not loss of oil pressure.
JMR
Quote from: ribbert on December 21, 2011, 08:18:35 AM
How can you say that for sure? Do you have an accurate oil pressure gauge to absolutely know for sure or are you just pointing out the difference between a level gauge and a pressure gauge? All the oil is moving to the back of the engine (in the case of hard acceleration) which means it isn't gathered around the pick up. Modern oil pans have very deep sections with long pick up tubes...the baffling in the FJ pan is basically nonexistent. On very mild inclines and under full throttle acceleration I can have that light on from 1st through 3rd gear.......that is a long time.
A quote from HSR to me in an email......"Yes, I do. I made them for the FJ1200/1300 for the Baby Grand Stock-cars under long sweeping right handers the pressure would fall. It's about 78.00 comes with pan Gaskets and directions. It has a tray & baffle."
  I think that validates my point.
FJ111200
Just out of curiosity JMR,  at what level in the sight glass do you keep your oil level? I always fill mine up to the top line or just above.
I have only experienced this sloshing of oil to the back of the engine once, and that was when i was waiting at some traffic lights and facing uphill.
I don't have the problem now as i've only got a separate speedometer and no standard gauges to warn me. :biggrin:
my 1349 engine with lightened crank accelerates faster than anything i have ever been (semi) in control of and my oil light will not come on under any acceleration situation.
However my rear ride height is increased over stock which tips the engine forward as well as improving the handling.
maybe you rear shock needs an upgrade to keep the bike from squatting so much on a hard launch?
those baby grand cars sit the engine sideways as well and who knows at what angle?... completely different setup from the bike for sure.
JMR
Quote from: racerman_27410 on December 21, 2011, 11:45:47 AM
I run an Ohlins rear shock (custom length remote preload adjuster) with a heavier Hyperco spring. Front is all Racetech with the tubes dropped a bit. Oil is run at the upper level mark and set with the bike on a level Handy bike lift. Several level gauges have been used with the same result. I am assuming but I have to imagine the cars run the engines very close to level if they are using a wet sump system. A dry sump may allow different placement.
Quote from: JMR on December 21, 2011, 12:41:30 PM
Custom length shock ?   so where is your ride height?
for comparison say if the bike is on the centerstand  is the rear wheel touching the ground?
    if the oil is running to the back of the pan that much there has to be something else going on if the engine is not leaning back... maybe the wiring from the oil level sending unit?
This comment should be the answer to your own question...
I am surprised more guys with street bikes haven't experienced the oil movement problem I have encountered.
Since no one else, either bike or car, is having problems; it is not a problem...
As just a quick example; every Legend or Thunder Roadster car that finished in the top five at a 2011 national oval or road course event had the oil pan removed to inspect for baffles. There was not a single one of those cars that had one installed, that is a total of 40 cars/engines that do not have that "baffle" and they do not have oil problems. :unknown: I wonder how they do it with out that "baffle"? Oh wait, it's not a problem :ireful:
If your oil light is on it is more about your "oil level sending unit" float not floating to the correct level or your viscosity is gone.
I can tell you that I would never spend a dime on one of those "baffles". If oil starvation was a problem then they would never last in a race car going around in a circle with gravity pulling the oil away from the pickup screen, just like you accelerating, only 100 times more G-force.
The G-force is so strong that a hose must be run from the breather fitting on the case to a remote one quart overflow/breather bottle because the oil level fills the front cover breather passages and it pushes the oil out the breather. You will never experience anything close to that on you bike unless you can get your FJ up on a 125 mph wheelie for 1/4 mile.
As far as oil level, we have to check oil level with the engine running because oil the amount of oil cooler volume and the drain back.
I run my oil, in my race cars, at the bottom line with the engine/oil hot. Sure the oil pressure gauge drops under acceleration & turning, but it has never been an issue.
If the oil pressure was a concern for Yamaha you would be able to find a "oil pressure specification for idle and a specified engine RPM", but you will never find one.
From my experience the average oil pressure for an FJ at idle when warm is 3 lbs and the 2500 rpm range is about 20-25 lbs. Sure, HSR sell a "kit" that they make that makes the oil pressure "higher", but if you really want to see the oil pressure numbers higher, install the oil pressure fitting on the pressure side of the oil filter before the pressure drop of the filter. You will see numbers above 50 lbs pretty regularly.
(Hmmm, I wonder where his oil pressure fitting is located... :scratch_one-s_head:)
One last point, and I am telling you this as a FJ engine builder, not a "FJ performance engine builder, part manufacture & seller", if you really look at the position of the oil level sensor you will see that the sensor is approximately 1.5" higher then the level of the pickup screen, so just because the light is on doesn't mean it is starving for oil.
Once you get that baffle and get it mounted, take a good hard look and then realize when the oil does pass between the small gap left around the pan at the baffle to the top of the baffle; it will just sit on top of that baffle until you decelerate and force it forward over the front of the baffle and back into the sump.
Thus the reason I never had and never will never use one...
Damn...Two pieces of aluminum and a gasket $78.00  :nea:
Oh yea, one more thing that really makes me wonder :unknown: and is a case of "monkey see, monkey do"... HSR and 99% of the other performance race car engine builders like to "shim" the oil pressure "relief" valves to "raise" oil pressure. One question that no one has or ever will answer for me; How does increasing the "relief" pressure raise the oil circuit pressure?
The oil pressure has to reach a certain level before the relief dumps the pressure, so how does shimming it actually raise the pressure. If you just shim the "reliefs" like they do and change nothing else, the oil pressure gauge will read the same.
(HINT: They are relief valves not pressure regulators... :dash2:)
But hey, they are selling parts...Isn't there an old saying about a "man & his money..."?
LOL Randy....  Ken told me when i inquired about installing an oil pressure gauge on my engine.... he said
"an oil pressure gauge would just scare you" and " dont worry about oil pressure.... oil temp. is much more important on this engine"
