Fuel gauge
Started by Imkruzen, June 16, 2009, 09:11:38 AM
Imkruzen
This is the next annoyance I'm perusing on this 84, now that the dash lights all work.
The fuel gauge doesn't go up to the F. Sits at about ¾ when I fill up. Then when I'm at 60km. the gauge is showing ½. From there to empty I put 230km before it goes to E. Last time I let it go until the light came on so I could pull the fuel sending unit. I did that. Cleaned the contactors on the rheostat and the harness plug. Reassembled it and went to fill up. It took 13L of the 24 full capacity? So it appears that the low fuel light indicator is coming on prematurly as well.
Is it possible that the whole assembly is sitting too high up in the tank or bent upwards?
sure its possible.......i bent the wire on mine so the low fuel light comes on with exactly 1 gallon of fuel left.
frank
Andrea70
Hi guys, can someone tell me how many kilometers do you run before the tank from total filled goes in reserve?
Today I run alla day long, not faster, around 70-100 km/h. And my total km was 190. I think it is not much, for close 16 litres of gasoline..
What do you think?  :scratch_one-s_head:
Ratchet_72
Quote from: Andrea70 on August 06, 2009, 05:41:59 PM
Andrea you even type an Italian accent...Priceless! :blum2:
Jason Cox
2000 Honda CBR1100XX
1977 Ironhead
Sacto, CA.
Hello Andrea,
I usually get about 250kms before the light comes on, 300kms before I need to switch to "reserver", and *once* got to 401kms before coasting to a stop :-(.  My '91 took just over 22L to fill from that point.
Andrea70
rnie, how possible you run for so long km?? I had difficulties to reach 200, and you made 400!! tell me the secret: you have someone who pull you from back.. uh?   :smile:
then I think my bike has some problems..   :dash2:
Andrea,
Your bike may have some problems, but its hard to know exactly.
My bike has over 120,000 kms on it now and is is pretty good mechanical shape.
I have Uni dual-pod filters, slip-on exhaust cans, and the valves and carbs are properly set.
Frequently people will put big jets in thinking that will give them more power, when all it really does is waste fuel.  I have 17" radials F & R, which probably helps a bit.  The engine is no longer "tight", so internal friction is likely minimized.
On that run, I was just cruising along at about 100kph steadily.  No big accelerations, no stop/start city work.  Tires are at 36/42psi cold pressure.  I had also topped up the tank before starting, so might have had that last 1/2 L of fuel in too.  It was a pretty boring day, btw.
In more normal use, I get to about 300-350 before filling.  And, just to complete the picture, I am not a tiny boy @ 182cm and ~100kg.  I also have a fairly high screen extension.
There!  You have a goal :-)  Work to it :-)
threejagsteve
When I was using my FJ for a daily 35-km commute on L.A. freeways, I would go about 300 km between fillups. That was mostly 2nd and 3rd gear, about 70 kph average speed.
I think that if you are getting such poor fuel economy, at minimum there is something wrong with the tuning of the bike. Have you looked at the condition of the spark plugs?
Cheers, and good luck!
threejagsteve
Andrea70
Arnie, your 350 km are a dream for my bike!  :shok:
Today I reached 210 km before stopping to fillup the tank. Just a couple of times I run till 150 kph, for half kilometer. The traffic doesn't allow us to run faster. And I do not like to run too much faster. (fortunately no cops and no tickets   :good2:    )
Threejagsteve, I have my FJ since 3 weeks, the owner before me is a pedantic bike's mechanic, and he made himself all the works to put in the original set the FJ. So I consider he made all the works as Yamaha done in original.
I don't know what to think.. I will wait a couple of months, in hope the FJ will drink less than now.
Cheers.
Andrea
Andrea,
I wonder if you may be using the fuel guage as if its accurate, it is NOT.
I usually get to about 150 kms when the guage shows 1/2 full.  The needle is at the Empty mark at about 250 kms, but the bike doesn't cough till 300 km when I have to switch to "reserve".
If your tires are a bit soft, or your gearing is low, or you actually USE the acceleration the FJ allows, or you regularly keep the engine in the 5-9000 rpm range - your milage will be worse than what I'm quoting.
Also, using your figures of 190km for 'almost' 16L, you'd get 261kms from the actual 22L the tank holds.
I would perhaps look at the needles and emulsion jets for wear and replace them if needed.  You could also make certain that your air filter is clean.
Andrea70
Thank you alot Arnie, you wrote something very important. I mean that in middle tank fuel I reach around 150 km, and it's the same like you. My thought was that when the gauge is on the "E" (empty), I thoght to go to fillup. But as you wrote, I've to wait to switch in reserve, then not when the gauge is up the "E". Even if yesterday the needle was in "E" on 210 km (missing 40 km more..)
Last time, when I filled up, the gauge was upper the "F" for 40 km. I filled until 2 centimeters from the top.
I don't think that half kilometer run on 160kmh needs one liter of gasoline. Cause if it's right, tomorrow I sell the bike!  :dash2:  :flag_of_truce:
Bigfoot
Does the 84 have a reserve switch? If so, where is it? I haven't found one yet on mine.
1980 XS1100 Midnight Special
doright1
No reserve, just a low fuel level warning light.  Mine comes on when I have about a gallon left in the tank.
Bob P.
'84 FJ1100
Greeley, CO
Don't steal.  The government hates competition.
Bigfoot
Thanks, that is what I thought. My fuel gauge never goes all the way to full either and the last time my warning light came on I still had 2 gallons left. Guess mine needs some adjustment as well.
Andrea70
Friends, good news!
After 2 times by feed pushing my FJ, and alot of bad curses to the hell, the mechanic reached the cause of the few kilometers.
The choke cable was blocked about the long time stopped.
Cleaned everything, now I hope I will run for at least 100 km more than b4.  :smile:
