1989 FJ1200 "Flat Spot" around 3500 rpms... V&H Supersport to blame??
Started by lumberjack2277, November 11, 2011, 09:32:01 PM
lumberjack2277
    Hey All,   I'm new to the board! ;-)    I have a 1989 FJ1200.  Starts right up, a little cold natured though.  All works great, has great power, except it has a flat spot right around 3500 rpms.  The bike has a Vance And Hines supersport 4-1 and unifilter individual carb air cleaners.  I dont know if its ever been jetted or not.   ANy advice?  I know its kinda' broad of a question... thanks for any input.
weymouth399
Pull carbs, clean carbs, and then find out whats in them for jets. We will be able to help you with a little more info. These bikes LIKE fuel and factory jetting is slightly close at best, if not plugged by years of rust in the tank, varnish or what ever.
But if I had to put a guess I would say you need a adjustable needle or a bigger pilot jet. Or a combo of both.
Bob W
84 FJ 1100
86 FJ1200
89 FJ1200
5  FJ POWERED race cars
76 LB80 Chappy
93 KX500 ice for sale
00 KX500 ice/dirt
04 KDX220 dirt for sale
04 KX500 ice
08 KLX450 ice/road
72 CT90x2 for sale
Naw, that's the jetting.  There is always a flatspot with a 4-1 pipe, but it's generally up higher and pretty subtle, probably between 6 and 7k, right before it tears your arms out.
fj11.5
ive wrong  before, but try raising the needles in the top of the carbs a notch, if they have them or a thin washer under each ,should be detailed pics on here if you do a search
84 Fj1100  effie , with mods
my supertrapp pipe had a similar flat spot but the jet kit i bought had an "optional" air correction jet 44 or 45(?) that pretty much cured it.   the air jet screws into the back of the carb at the air inlet opening.
SlowOldGuy
Quote from: racerman_27410 on November 12, 2011, 05:07:15 PM
That would be the optional (richer) 144 air jet that a DynoJet kit includes as opposed to the stock 155 air jet.
