gsxr wheel spacers
Started by fj11.5, October 31, 2011, 05:13:05 AM
recieved the 17" wheel today, though it only needed a bearing, turns out i need the spacers as well, it has the innner wheel one and a short stepped spacer i think goes on the disk side, just wondering if washers could be used , or if there are pictures hiding on here, wheel is an 88/89 j/k 750 model
FJ111200
Is this fische any good to you?
http://www.cmsnl.com/suzuki-gsx-r750-1988-1990-usa_model16084/partslist/98132.html
Or do you need pictures of the GSX-R to FJ conversion?
billwest
64741-17E00 SPACER,REAR AXLE,R
64751-46E00 SPACER,REAR AXLE,L
These are the Suzuki parts I used for my conversion.
Sold it!
thank you, i spent about an hour looking for a fische , buggered if i could find one, , and thank to the other fj,er for the part numbers , both will make the search so much easier
gripit_N_ripit
Curtis
gripit_N_ripit
Nevermind...MR cycles has a great site to skim through. i found it there.
Curtis
billwest
Sold it!
Alf
Quote from: fj11.5 on October 31, 2011, 05:13:05 AM
mmmmmmm  I think you have bought a 4,5" rim. The recommended fitment is 160/60/17. You need a 5,5" rim to fit a 170/60/17 or 180/55/17, >90 SACS 750/1100 models
You only need 2 big flat washers at each side. See my web, rim swaps section
Hi Alf , your right mate , its  a 4.5 rim, has a 170 tyre fitted, ,if I can make it work I will ,as I can't afford another , if I get too stuck there are 2 machining places not far away, and one deals only in stainless good work and prices , ,going into surgery soon so I can't even test fit ,and still waiting on the caliper bracket ect ect , kind regards rod
