Spanner wrench for a Penske Sport Shock?
Started by markmartin, September 26, 2011, 09:04:35 PM
SlowOldGuy
With a spring rate in the neighborhood of 1000 lb/in, it's going to be hard to turn even with a bearing
markmartin
Quote from: RichBaker on September 30, 2011, 10:23:40 PM
You do have her up on the center stand, don't you?
I sure do, on the center stand, perched on a  block of wood, so the wheel is off the ground.
Quote from: SlowOldGuy on September 30, 2011, 11:37:41 PM
1200 lb spring.
My new Cycle Gear catalog came in the mail, there are three spanner wrenches listed in the back. The one for $7.49 is the one that I am pretty sure will work.
We use something very similar on the coil over shocks we have on the race car as well.
I now have the bearing kit in stock for your Penske shock; Coil-Over Bearing Kit
I also have two different spanner wrenches on the shelf as well.
Adjustable Spanner Wrench
Non-Adjustable Spanner Wrench
Quote from: racerrad8 on March 19, 2012, 08:37:21 PM
Damn Randy!!! When are you gonna have a brand new FJ in stock???? With all the upgrades already included of course.....  :biggrin:
Quote from: FJmonkey on March 19, 2012, 08:46:31 PM
I am here to serve and supply the FJ habit whether stock or modded...
Mike 86 in San Dimas
Mark,
Penske includes a Torrington Bearing on shocks with heavy spring rates, so there should be one on there already. If you look between the spring perch and the spring you should see a flat washer on each side of the bearing. If you would still like the shock sock, (which is a good idea) I can send it via flat rate USPS for $5.99.
ote]
The web site shows the sock for $17. Is the $5.99 just shipping or is he giving you better price for buying the shock?
Mike
Quote from: Mike 86 in San Dimas on March 19, 2012, 09:37:21 PM
Mike
I am also having shock socks made as well. I am waiting for the prototype rear shocks to fall into my hands before I place the full order to confirm they are going to fit properly.
I am thinking about having them made in two colors; Black & Red.
Quote from: racerrad8 on March 19, 2012, 09:43:25 PM
Mike
Case and point!!!
