forks!!hell
Started by robbygixxer, September 18, 2011, 04:23:59 AM
robbygixxer
hello all
So im getting there with my fj project but have noticed something a bit alarming, the front forks seem to be very soft, now im thinking..drain out old oil & replace with a slightly heavyer grade..but, im still new to this bike and am still finding my way around it so was wondering if anyone knew a minor mod i could do to firm up the damping a touch, its an fj1100 on a 84 plate.
thanks peeps
elbows
Quote from: robbygixxer on September 18, 2011, 04:23:59 AM
hello all
thanks peeps
i mix 15w and 10w fork oil that stiffens up the front end what would help is progressive for springs as well
old racers never die  its the stories just get faster
3 bikes all 3cv
Measure the sag to start.  If it's >35mm or so, it's time for uprated fork springs, either progressive or straight-rate, depending on your preference.  If you're a true cheapass, you can put a small spacer in atop the spring to increase preload, but it's kinda a bandaid and not really a substitute for having the proper spring in there.
If the sag's acceptable, then it's time for new oil in there.  If they're low/dry on oil, it had to come outta somewhere, and odds are pretty good that the seals are popped.  Easy enough fix, a fair bit of work and somewhat intimidating the first time, but not difficult by any means.
flips
+1 to what elbows and Andyb said,
I also used a 50/50 mix of 10 & 15 mix of fork oil.Worked well on my 861tx.
Cheers :drinks:
Jeff P
Stay rubber side down.
