The brake pedal
Started by vulcanbill, May 21, 2009, 07:06:15 AM
vulcanbill
n8man1068
Normal that it's ground down? At that angle, I'd imagine that its not.
Factory Pro Stage 1 kit
Vance and Hines SS2-R
RaceTech fork springs
Corbin Gunfighter and Lady seat
'86 FJ1200 gas tank
rvnmaniac
 Must be stock susension.......
"GO RAVENS"
the fan
Quote from: vulcanbill on May 21, 2009, 07:06:15 AM
Is this normal?  Wifey's bike after our recent trip.   :shok:
http://farm4.static.flickr.com/3323/3547024054_7a0d5b743f_b.jpg
It really does not that much of a pace to drag controls on a winding road. Thats why I gave dean his bike back after a few too many (s)miles.
ddlewis
Lots of us have had that problem.  If she's long legged enough and doesn't mind a taller seat height, shorter dogbones will give more clearance..  and save the toes of your boots.
vulcanbill
Quote from: ddlewis on May 21, 2009, 02:37:19 PM
She is and she wouldn't.  Where might one acquire said dogbones?
Looking at the angle that it's ground at, looks like it'd be best to raise it a bit, looks like it's set quite low.
vulcanbill
Quote from: andyb on May 21, 2009, 09:33:40 PM
The pedal or the bike?   :biggrin:
The pedal.  The bike is getting fairly low too, it would seem....
I want to say I grind near the start of my midpipe long before the brake lever though, so probably depends on how your stuff is setup.
ddlewis
You'd have to have it made, unless somebody knows a swap.  Would be easy to make if you know anybody w/ metal shop.  Dean has them.. Dean where'd you get yours, Jon Cain?
the fan
I can have a set made if someone can get a measurement for me. I dont have a bike to check. cost would be around $45.00
Or I can just send a drawing and you can have a set made yourself. Its nothing magical, and any machinist can make a set out of 1/4" mild steel stock.
tqmx1
What year FJ are you talking about? If it is pre 87 you are SOL 89 and up you can have different dog bones made.
My looking at the photo my guess it was downed at sometime in it's life and they did not replace the lever and you just spotted it. Look at the bike and see how much stuff you would have to clean off before you would get down to the lever (like peg feelers the pegs them selves not to mention boots are a early touchdown point)
Take a look at Klavs 08 west coast rally movies and see where his toe is touching down well before anything else.
Just take a file & smooth off the rough spot and see if she does it again.
For the 89+ you can get adjustable ones made even, which are lovely.
Google Soupy Links, I don't know if the guy even still does it.
vulcanbill
Quote from: andyb on May 22, 2009, 08:17:20 AM
Pedal is basically where it needs to be.  She's got a lot of miles on this bike and it's set up perfect.
vulcanbill
Quote from: tqmx1 on May 22, 2009, 02:59:15 PM
It's a 91.  It's never been down.  She keeps the balls of her feet on the pegs during brisk riding so she rarely gets boots down anymore.  The pegs have taken a fair amount of abuse.  This is the first time, to my knowledge, that the brake lever has dragged but the bike was loaded up w/ two heavy e41s and a V46.  In addition, I replaced the original rear shock w/ a stock shock w/ low miles before we left tho settings were the same.  I think it's just time to raise it up.  The brake pedal suffered that fate on the Parkway.  I was behind her and saw and heard it as I often do.  Just didn't know it was any different than any other time.  Interested in learning more about raising it up.  She needs the room apparently.
BillO
