RPM Parts Update
Started by racerrad8, September 09, 2011, 08:08:21 PM
Now through December 25th the Zumo 395LM Navigator is $100 off of the original price of $499 Zumo 595LM Navigator is $100 off of the original price of $799. I have adjusted the price to reflect these sales until December 25th. Both of these models are compatible with Garmin TPMS Sensors
Robert - RPM
Tomorrow, December 20 3PM P.S.T will be the last day I can ship anything to the lower 48 and it still arrive by Christmas.
If you have any inkling that Santa needs to put some RPM goodies under the tree, now is the time.
Don't forget, if anyone in your family needs a gift for you, they can always get a RPM Gift Certificate to stuff in your stocking.
Merry Christmas everyone, Randy - RPM
Our latest shipment from Yamaha is in and we have a few new items that we have added to our inventory
Genuine Yamaha 4 brush Starter
Genuine Yamaha XJR Series Alternator (Now available in black)
XJR Alternator Bolt (Needed to swap to the new XJR alternator)
The Yamaha Slave Cylinder are now back in stock as well.
Robert - RPM
Robert,
Forgive my ignorance but I thought early FJs had a 2-bolt alternator and the later models had 3 bolts?
Did I dream this? Or, did they keep the original 2-bolt pattern and add a 3rd boss for the later model?
Thanks,
David
Quote from: FJ_Hooligan on January 09, 2018, 06:15:34 PM
Robert,
Thanks,
David
Yes, early model FJ's had the two bolt alternator. I believed that changed on 86 model FJ1200. My two 86's have a three bolt alternator.
The XJR alternator will be a direct bolt on replacement for either two or three bolt blocks.
With the addition of Garmins' new 5k action camera, the Garmin Virb 360. Garmin has reduced the current cost of their current action camera, the Garmin Virb X
by $100. Now making them only $299.99.
Garmin Virb X in action Priest Grade Road
Robert - RPM
The majority of the latest order has arrived from Yamaha and we have gotten a few hard to find parts.
We now have in stock the fairing protectors for both sides of the 84/85 and 86/88. If you recall the right fairing protectors have been obsolete in the US for many years now and unobtainable. Not anymore, we have them on the shelf and ready to ship. No need for people trying to get them made via 3D printer or looking for NOS. These are brand new current production inventory.
84-85 Right Side Fairing Protector 2
84-85 Left Side Fairing Protector 1
86-87 Right Side Fairing Protector 2
86-87 Left Side Fairing Protector 1
We now have the small "Cover, Oil Pump 2" on the shelf as well. It is available in both black and silver. That cover along with the "Cover, Oil pump" (timing cover), the Clutch Cover, Outer Ring and Clutch Cover, Cap will transform your engine to a shiny new look.
Genuine Yamaha 4 Brush Starters are back on the shelf too.
I know they are pricier than the current aftermarket options, but you know you are getting a quality part. When you are broken down on the side of the road you will soon regret the money saved...
If you have not heard about the lower quality standards of the aftermarket units, have a read here: Beware of eBay/aftermarket starters
We have a couple of other parts on the water right now heading our way that will be exciting additions to the inventory.
Robert has also been working very hard to come up with a solution for the gravity feed bike is reference to the fuel line and plastic Y fitting. We are currently testing a new system that is promising. We are going to have to await some warmer weather to make sure we don't have any issues. If everything works out well, we will have this available for those with gravity feed carbs as soon as we are confident this is the best replacement option.
I will continue to strive to obtain, manufacture and provide the parts you need for your beloved FJ. I have and will continue to invest int he FJ platform as they need to be represented for many, many years to come.
I appreciate everyone's ongoing support and loyalty to the FJ.
Mike m
Idk What I would have done without rpms help on my engine needs.ill always be a loyal customer.thanks rpm!!!
Added a few Motul items people have requested as well as the main jet washer that seals between the main jet and the emulsion tube
Main Jet Washer
Motul Air Filter Oil Spray
Motul Chain Clean
Motul Chrome and Aluminum Polish
Motul Shine & Go
Motul Wash & Wax
Robert
We received another Yamaha shipment in yesterday and we were able to lower the price on a few items as well as add a few new items to inventory.
Genuine Yamaha FJ1200 Fuel Pump
89-95 Short Fuel Line
1984-1993 Center Stand Spring
Yamaha Nylon Fairing Washer
Yamaha Fairing Screw
Vacuum Cap Clamp
Fork Leg Drain Screw Washer
86-95 Yamaha FJ Clutch Lever
Sprocket Cover Dowel
A big thanks to everyone that supports us. You help us to be able to grow and continue to provide parts and service for the FJ and this community.
Robert - RPM
The RPM 2017 Valentines Sale has begun and will run through February 18th.
Now you can get something special for your true love...
Your Yamaha FJ
See your coupon code for your discount in your membership section.
If you are not a contributing member it is not too late, you can go to this link for all of the details: Membership has its privileges
FJowners.com membership has it's privileges.
Thank you for your continued support, Randy - RPM
We have received a few items that have been out of stock for some time.
We ran out of a few valve shim sizes and they have been replenished: Genuine Yamaha Valve Shim
The Blue Yamaha Hats are back on the shelf as well.
We ran out of swing bearings and 84-93 FJ Fuel Sender Unit Gasket. The back order from Yamaha has finally arrived.
To answer the most asked question of recent times, yes the vibration dampening handle bar ends will be available again. I foresee a month or two, but they are in the works.
Thank you as always for your continued support.
It has been a while since we have posted any sort of part update, but today we finally got a biggie back on the shelf.
I had to search out a new company to start production of the newest version of the RPM handlebar ends. Since the original manufacture has halted production, I had to go out and re-tooled to get them manufactured. We have made some improvements in the area of the tuned mass damper in relation to corrosion. It is now made from stainless steel instead of plating the original steel design. This should stop the corrosion issues that had been documented prior.
I am sure there are several other things that Robert can add on, but I wanted to get this one out since the new RPM handlebar ends are now back on the shelf and ready to ship out.
If you had requested notification, should have already received it from the auto-reply from the website.
Thank you for your continued support.
PaulG
When I click on either link I get the Genuine Yamaha Valve Shim   :scratch_one-s_head:
1992 FJ1200 ABS
YouTube Channel Paul G
RPM - Robert
Fixed it. However, there were 30+ people on the wait list and we only received 15 sets. They have already sold out, we have more on the way but they are currently at powder coating so it may be a week or two before they are back in stock.
