Petcocks Question
Started by nvmike24, September 07, 2011, 07:01:13 AM
nvmike24
I  pulled the tank to inspect my 84. Sure enough my outlet fitting moved very easily. I squeezed it back into proper position and wired it into place. I found out also that when the hose is off fuel drips out the fitting with the hose off and no vacuum from the engine is supplied. Petcock not being available I am wondering what to do. Can the newer petcock be installed in its place or is the newer fuel tank design able to be fitted without changing other items?
Mike Sweeney
83 CB1000C, SOLD
84 FJ1100, in little pieces, for powder coating, FZR1000 Front
Fork Mod and Trans repair!
12 Road Glide Ultra
Hey Mike, I moved your question out of the Files Section and into this section.
You have a leaky petcock.
3 options: 1) Buy the O rings and spring and rebuild your old one
               2) Buy a new petcock. Yes the new oem vacuum petcocks are still available for the 84/85 FJ's.
               3) Go to a aftermarket petcock. See Randy @ RPM, he has the Pingel petcocks.
Cheers! Pat
weymouth399
They are available they just cost alot. Yours is the 2nd most expensive one.  :dash1:
86-87 are alot more but priceless if it keeps your bike from catching on fire.  Feel free to chime in Dan.
89 later are cheap.
Bob W
84 FJ 1100
86 FJ1200
89 FJ1200
5  FJ POWERED race cars
76 LB80 Chappy
93 KX500 ice for sale
00 KX500 ice/dirt
04 KDX220 dirt for sale
04 KX500 ice
08 KLX450 ice/road
72 CT90x2 for sale
nvmike24
My local Yamaha Dealer said the assembly was discontinued. Ill check with Kawasaki on the pieces to repair.
Mike Sweeney
83 CB1000C, SOLD
12 Road Glide Ultra
