Valve Shim Kit
Started by racerrad8, August 25, 2011, 07:51:33 PM
After multiple requests over the last several months I have added a valve shim starter kit to the website. This kit includes the storage case and twenty (20) new shims to get you started.
This is where you can find it; RPM Valve Shim Kit
This kit does not include the tool which is located here; Valve Adjusting Tool
I cannot modify the starter kit package, but you can add shims to the set as I have the listed individually here; Valve Shim
Thanks again for all of your support,
