changing carbs diaphragm
Started by draku, July 27, 2011, 02:15:44 PM
draku
because I had some problems with carburetor diaphragms, I ordered a set of 4 pieces in www.motorradbay.de
they cost 29.90 euros each, so 130 euros in total including transport
very good quality
some pictures from the assembly
package that I received
my diaphragms (original)
position mark
is important that the diaphragm be positioned exactly in the same position, to maintain slide position inside carburetor
cut the upper plastic ring
carefully remove the ring
bottom ring
adjusting the upper ring (~ 45 degree) with a file
mounting the new diaphragm
mounting modified ring, glue, secure (for about 8 hours) with a zip-tie
That looks to be pretty straightforward.  How do they work?
draku
works very well
glue is resistant to temperature, no problems until now
engine throttle response is quick
