Carb Sync Tool
Started by Slick, July 21, 2011, 02:23:29 AM
Which of the following HAVE you HAD exp with AND like
Carbmate TS-111
1 (7.1%)
Twinmax
0 (0%)
Cheapo Vacuum gauges
2 (14.3%)
Carbtune
13 (92.9%)
Total Members Voted: 14
Slick
I am about to purchase a carb sync tool and would like to know which one will work best for the cheapest. Please only respond if you have worked with or seen work. Please do not comment on others opinions, dont make this a flame war.
Carbmate $100 2cyl http://www.vacuummate.com/carbmate/index.php
Twinmax $104 2cyl http://www.ascycles.com/detail.aspx?ID=2146
Cheapo Vacuum Gauges 2cyl $25 http://www.amazon.com/gp/product/B004MSJ7C8/ref=noref?ie=UTF8&s=automotive&psc=1
Carb tune 4cyl $108 http://www.carbtune.com/
I have one, cant remember the brand , its a 4cyl model, the same as RPM  sell , works well, easy to use
Lotsokids
I would prefer the Carb Tune. It keeps the readings close together. I have a cheap one with analog guages that I bought from Ebay for about $70. I think the brand is Kymco. It's O.K.
weymouth399
I used a vacumate last year it was the balls. Very pricey but tells you a lot of things.
Bob W
84 FJ 1100
86 FJ1200
89 FJ1200
5  FJ POWERED race cars
76 LB80 Chappy
93 KX500 ice for sale
00 KX500 ice/dirt
04 KDX220 dirt for sale
04 KX500 ice
08 KLX450 ice/road
72 CT90x2 for sale
Here is what I have to offer. I have sold 5-6 since the website web on-line and no complaints.
http://www.rpmracingca.com/proddetail.asp?prod=Carb%3Asyncpro
Lotsokids
Quote from: racerrad8 on July 21, 2011, 10:01:18 AM
Yes, buy the one from Randy. He's well know 'round these parts, and has a lot of happy customers here. :hi:
MyOwnFJ1200
Ive used the carbtune carb stix many times and they wor wonderfully . I would recomend them anyday
Brian
MyOwnFJ1200
those look similar to the carbtune ones
Brian
The Motion pro looks like a nice setup.
The major difference between the Carbtune and Motion Pro is the Carbtune uses polished Stainless Steel rods instead of a manometer fluid in the Motion Pro.
I bought the Carbtune years ago and it has been worth every penny.  :)
Hey randy, allready gave you a free add of sorts :)    but yep, thats the set i have, thanks for the pic :)  :)
Quote from: pdxfj on July 21, 2011, 11:39:52 AM
Yep I've used the Motion Pro for years. The old model that had Mercury, back when you could buy Mercury.
It's a right of passage....All FJ owners who have liquid in your balance sticks HAVE to go through...it goes like this:
1) Engine warm: check
2) Tank off, aux tank connected: check
3) Rubber caps off, hoses connected: check
4) Start engine: check
5) Idle at 1000-1200 rpm: check
6) Balance carbs #1 to#2: check
7) Balance carbs #3 to #4: check
8.) Balance left bank #1/2 to right bank #3/4: check
Now for a little blip to clear her throat: check......Wait....Where the fuck did all the Mercury go?
No worries with my Morgan Carb Tune. I've got to REALLY screw up before one of those stainless rods get ingested.
carsick
Morgan Carbtune, works great, no experience with the others.
Travis398
Quote from: Slick on July 21, 2011, 02:23:29 AM
and would like to know which one will work best for the cheapest. Please only respond if .............
sounds easy
Quote from: weymouth399 on July 21, 2011, 05:21:48 AM
Bob W
As you can see Bob likes to give his opinion.............even when you don't want it.
hein
   Over the last few decades I've had four different types, two homemade, two store bought. First homemade one I used individual vacuum gauges, hoses and resrictors. They worked OK but had more needle flutter than I liked so they finally got binned. Next one I made was the individual manometer style using mercury. Constant worry concerning sucking mercury into the engine caused me to bin this system also. First store bought system was a Motion Pro using Manometer fluid which worked fine but unfortuneatly developed legs and walked away never to be seen again. I now have the Morgan carb tune which works great.   Hein.
Slick
Quote from: Travis398 on July 21, 2011, 05:19:45 PM
sounds easy
Bob W
I dont know if you are aware, but commenting about someone else's comment, is still just that... lol  :empathy:
