Stock weight for 86 FJ
Started by ktmaha, July 18, 2011, 08:41:32 PM
ktmaha
Anyone know the true weight and f/r bias of the 86 FJ? The few pages I have seen online go from 271 to 298 lbs.
I have done some mods to my bike and was curious to see how much I have been able to drop.
Thanks
1973 Yamaha CT 175
1986 Yamaha FJ 1200
1996 Yamaha TTR 90
1991 Miata @ 8psi
Quote from: ktmaha on July 18, 2011, 08:41:32 PM
Thanks
Sounds like a fully custom Titanium FJ600 to me, anyone else?  :biggrin:
Do you have a bath scale?  Run each wheel up on the scale & see what you get ...
Kilograms are not pounds.
540lbs dry was the first number I found.  Add a bunch for wet weight.  I've never seen the weight bias listed for an FJ.  A bath scale with a decent capacity used at each end will be the best way to see where you're at.
ktmaha
I have done the bath scale thing, 268F/245R with a half tank of fuel. Bike already had the aftermarket exhaust so I couldn't get before numbers. Bike has PS shock, GSXR forks and front brakes, Katana wheels. Rear turn signal mounts were removed along with bungy hooks. I did put an 89 front cowling on it, so that added some weight. The chin fairing was all broken up, so that was trashed.
1973 Yamaha CT 175
1986 Yamaha FJ 1200
1996 Yamaha TTR 90
1991 Miata @ 8psi
