Valve clearance confusion
Started by grannyknot, July 15, 2011, 06:02:01 PM
grannyknot
Yamaha service manual says to find top dead centre to measure valve clearance but how is that possible when at TDC both the exhaust and intake cam lobes are pointing at 90 degrees from the shim and are in contact with it?
I have always measured valve clearance with the lobes pointing straight up,180 degrees away from the shim
and have never had a problem, I just measured the fj this way and found 4 shims need to be traded for one size thicker. What am I missing here?
Thanks,
Chris
84 Yamaha FJ1100L
82 Honda CB450T
70 Suzuki T500
90 BMW K75S
Cam lobe should be 180 degrees pointing away from the shim.  BTW, that is NOT straight up since the valves are not vertical.
Maybe I am confused but "one size thicker" ? Generally the valve sucks in and you have to go thinner ? I can get confused so forgive me if I am off. :)
FJ111200
As long as the base circle area of the cam is somewhere off the face of the shim, and not the flat side and/or the lobe end of the cam about to come into contact with the shim, then you will get a reading or measurement.
grannyknot
84 Yamaha FJ1100L
82 Honda CB450T
70 Suzuki T500
90 BMW K75S
grannyknot
Quote from: movenon on July 15, 2011, 10:10:05 PM
thinner was what I meant, somewhere between the garage and the keyboard...  breathing in too much carb cleaner I think.
84 Yamaha FJ1100L
82 Honda CB450T
70 Suzuki T500
90 BMW K75S
