Knock knock...
Started by Carterc, June 07, 2011, 07:45:57 PM
Carterc
So i started up my bike today and my father pointed out a knocking sound that was in tune with with the shaking of the engine, if that makes sense. Im assuming this is a big problem... Please inform.
1986 FJ1200
Travis398
does the sound go away or get worse when you ride it at higher rpm's?
Carterc
I have no idea, my bike is to loud to hear it, i can only audibly hear it when i idles
1986 FJ1200
Camchain, starter chain, loose engine mount.
Less likely but more expensive is a bearing someplace.
what RPM is your idle set ?
the FJ likes to idle about 1100 RPM.... lower idle speeds can result in all kinds of weird (  but normal)  noises
Scooterbob
Loose exhaust possibly?  Cracked or loose fairing?  Trying to narrow down a knock or vibration on the FJ seems to be a "needle in a hay-stack" kind of thing.
Let us know what you find.   (popcorn)
-----Bob G.-----
Carterc
rpm is set at 1100 and the knock is definitely in the engine, i put a long screw driver on the engine block and listened to it by putting my ear on the end of the screw driver (poor mans stethoscope). Also, today i took the bike to work and when i got here it was smoking from the engine..... I'm no mechanic and I'm about to give up on this bike, this is ridiculous.
Chris
1986 FJ1200
Travis398
As Andy and Frank said it's not very likely to be anything more than weird/normal noises. As far as the smoking goes, your bike is 25 years old, a small oil leak is nothing to panic over. It is pretty common for the rubber seals on the valve cover bolts to dry out and leak, be a shame to give up over a $3 rubber seal.
Quote from: Carterc on June 08, 2011, 11:43:08 AM
Chris
Even when properly set, the clutch basket and cams both rattle and clatter a bit at idle....
nvmike24
 :music: have you synced the carbs? Low idle and carbs out of sync will make primary chain racket. I agree on the smoke issue, she be an old girl. Being loud does not prevent poor mans hearing aide from working. Bump the idle up to 1500-2000 and see what area you can find the noise loudest.
ps: what's the asking price? Just yankin your chain. Relax
Mike Sweeney
83 CB1000C, SOLD
84 FJ1100, in little pieces, for powder coating, FZR1000 Front
Fork Mod and Trans repair!
12 Road Glide Ultra
Carterc
thanks for all the help guys.
btw, the asking price is $1,000,000.00..... :rofl:
1986 FJ1200
Scooterbob
Quote from: Carterc on June 20, 2011, 12:31:30 PM
Take a check?   :lol:
-----Bob G.-----
Travis398
I like that  :good:
