Fork Seal Problems
Started by Lotsokids, May 12, 2011, 12:17:19 PM
Lotsokids
I replaced my fork seals about 6 months ago, but now they are both leaking again and I just noticed it is dripping oil on my front tire. NOT GOOD. Most of the roads I ride on here are extremely rough, so maybe that's what blew them out. I should ride on the grass next to the road, it's probably smoother.
Does anyone have a preference of type or brand?
Sounds to me like you didn't replace them with OEM seals...that is the problem.  ALL OTHERS ARE SHIT!  OEM is the only way to go.
+1 to what Marsh says..
Also what I do is use some 1000+ grit sand paper with some WD40 and gently sand off rough edges around nicks in the tubes.  Much less chance of them cutting up new seals.
Quote from: Lotsokids on May 12, 2011, 12:17:19 PM
Like Marsh said the O.E. seals are the best. The seals I sell are the NOK brand, the supplier to Yamaha and the exact same seal; http://www.rpmracingca.com/proddetail.asp?prod=M%2FC%3AForkSealKit
Also, if you have wear in the fork bushings then they will cause the seals to fail prematurely so here is your option for that as well; http://www.rpmracingca.com/proddetail.asp?prod=M%2FC%3AForkR%2FBKit
carsick
Or push your bike.
Quote from: pdxfj on May 12, 2011, 12:30:27 PM
Up and down, not around and around.
I've always used an Arkansas stone....
ddlewis
sometimes it's just a piece of grit and you can slide something thin in there and clean it out and it will stop leaking.  something like film negative (if you can find it), a real thin feeler gauge or some kind of laminated plastic card.  If you've been on a lot of gravel roads worth a shot before taking them apart again.
I cut a piece out of one of those plastic boxes they use to package so many things with now, use it to clean out under the seal lip... same shape as the thing Motion Pro sells.
Lotsokids
Quote from: carsick on May 12, 2011, 05:56:26 PM
Or push your bike.
LOL... That's awesome!
Thanks everyone for the advice! I will try to clean it out and see what happens.
I've found that fork seals last longer with a fork brace and a bug shield...and fender tabs don't crack....just so ya know...
craigo
Quote from: Pat Conlon on May 13, 2011, 03:00:43 PM
I concur this.  With a fork brace, the bottom sliders move in unison, causing little to no flex on the fender tabs.  Also makes the bike more stable around the corners.  Great invention, the fork brace.
CraigO
90FJ1200
CraigO
90FJ1200
jykkeh
Only OEM all others are shit.
mst3kguy
and triumph fork protectors.
dean
2014 triumph street triple r
2019 ktm 1290 superduke gt
E Double
Quote from: craigo on May 13, 2011, 04:09:43 PM
CraigO
90FJ1200
Now if they would just become available so I can purchase one I too would be able to agree with this statement.
There are only two kinds of people who are really fascinating: people who know absolutely everything, and people who know absolutely nothing.
    Oscar Wilde
