Crap! I used 14gauge for coil relay mod
Started by wakdady, April 14, 2011, 05:32:54 AM
wakdady
Will I be alright with the 14gauge wire? Or should I take it all apart and go buy 12gauge?
I guess I was on autopilot when i did it, lol.
:music:
I think you will be fine. The final proof is in the voltage drop numbers. Your before voltage reading was what, 10.xx volts? Now it's what?
14 gauge wire is still better than the 16 gauge oem wiring.
SlowOldGuy
Just don't put in more than 180 watts of lights on that line and you'll be okay.
Scooterbob
Quote from: SlowOldGuy on April 14, 2011, 09:38:35 AM
There are light watts on the coil relay mod?!
Do not argue with an idiot. They will drag you down to their level and beat you with experience.
-----Bob G.-----
SlowOldGuy
Ugh, I hate it when I don't read thoroughly.
Nevermind, you should be fine.
Quote from: Scooterbob on April 14, 2011, 02:09:04 PM
...or is that the coil solenoid mod??             :biggrin:
Scooterbob
Quote from: rktmanfj on April 14, 2011, 02:46:00 PM
The solenoid is what is getting the signal from the relay for the lights that are hooked to the coils.  :biggrin:
-----Bob G.-----
Oh jeez.  The big question isn't the lighting you run your coils with (arguably sparks are illuminating, if you want to defend yourself that way David...), but it's what kind of oil you use!
