3rd carb popping
Started by irishluck, April 02, 2011, 09:33:19 PM
irishluck
so i had to replace a cylinder head cover bolt, got it replaced, put carbs bk on and hooked lines up.  turn the bike on and idles fine. when i go to rev it up, the third carb from the left makes a popping noise and  a white puff of smoke comes out of the back of the carb
anyone knopw whats going on?
Several possibilities:
Lean idle circuit
Cracked plug or questionable plug wire
Leaking vacuum plug on synch port.
 It could even be crossed leads. Some combinations could produce those symptoms and if revving stationary, not particularly noticeable at idle. It's at least worth checking - always eliminate the obvious and the easy first.
irishluck
ya but it was weird cause  right before i replaced the head cover bolt it ran just fine
Quote from: irishluck on April 03, 2011, 04:36:01 AM
My Irish is a bit rusty.  Does this mean it's fixed?
irishluck
well it is now, just found out a couple drops of water got into it. That's why it popped and had a puff of white smoke out the back of carb
