oil in carbs
Started by theautoman21, April 01, 2011, 04:22:01 AM
theautoman21
oil is pouring out of carbs dont know why?
Travis398
did you overfill it with oil?
Quote from: theautoman21 on April 01, 2011, 04:22:01 AM
The only thing I can think of is poor ring sealing which in turn pressurises the crank-case forcing oil up the crank vent pipe into the air box?
fj1250
Make sure your petcock is shutting off.
The most common reason for this problem is gasoline overflowing from the carbs into the crankcase.
If you add a gallon or two of gasoline to the crankcase, it then blows back into the airbox as an oily/gas mix.
Check your oil sight glass on the clutch cover. Good chance your oil will look very clear and no air bubble at the top of the window.
MC
