PCV FLOW??
Started by gripit_N_ripit, March 29, 2011, 10:00:36 AM
gripit_N_ripit
OK GUYS IM BACK!!!LOL i was messing with my fj that has 55000 on the odometer. i had the engine completely warmed up and was setting the idle i accidentally removed the pcv hose at the air filter box. i saw a pretty good stream of smoke coming out. now given the mileage i would expect to see some smoke but i would like to hear your input. thanks
Curtis
Flying Scotsman
Sounds like a problem.Where does the smoke come from ?
1990 FJ1200
1999 GP1200 (165 + hp)
gripit_N_ripit
in my experience with cars. when you see smoke coming from the pcv usually means worn rings leaking combustion gases into the crankcase therefor exiting through the pcv. i think i'll try compression testing the motor dry/wet and that should tell me right? wondering how much is too much?
Curtis
was it smoke or steam ?  how long had it been since the engine was previously running ?
how long was the engine idleing ?  did you have a fan going on the motor ?
gripit_N_ripit
Quote from: racerman_27410 on March 29, 2011, 11:44:21 AM
looked and smelt like smoke. the motor has been running for 4 days after a year of sitting under cover. engine was idling for about 15-20 minutes with a fan blowing on the motor. no driveability concerns or engine miss. have not synched the carbs yet for lack of knowledge and confidence,but i did make a manometer and am talking myself into trying it soon. thanks
Curtis
Have you changed the oil?  How old is the oil?
There may not be anything wrong.  Remember, the bottom of the pistons move as much air around as the combustion side.  As a result, there's a lot of airflow in the crankcase and you're probably just seeing it coming out the breather hose.
Just for that reason, never remove the oil filler cap when the engine is running unless you want an oil spray bath.  Also, never start the engine with the clutch slave cylinder unbolted, crankcase pressure will shoot the actuator rod across the garage.
Burning oil or oil vapor?
Run it into a clean rag (paper towel, etc) and see if it smells like oil or burnt oil once you've collected some.  Oil vapor isn't a surprise at all.  Burning oil would make me wonder about ring seal issues.
gripit_N_ripit
I changed the oil 4 days ago and put sae 10w40 in it. i am changing it right now just to be sure its clean. ALSO, i wanted the absolute best oil for this engine the parts store next to my shop sells MOBILE1 vtwin 20w50 for aircooled motorcycle engines, would this be ok to use? yamaha told me not to use anything but yamalube.
Curtis
carsick
Quote from: gripit_N_ripit on March 29, 2011, 03:32:16 PM
MOBILE1 vtwin 20w50
Might be transplant rejection issues! It should work but is pretty thick, unless the motor is really tired the clearances are tight enough that it doesn't need a heavy oil. Whoops, I think I just got suckered into posting an oil thread opinion, now I've done it.
Travis398
Quote from: carsick on March 29, 2011, 06:13:14 PM
MOBILE1 vtwin 20w50
or you live in the desert, like say New Mexico
I run 10w40 year-round, I live in Tucson,AZ........ Not a problem, even at 110F.  Stick with 10w40.....   :drinks:
carsick
Quote from: Travis398 on March 29, 2011, 06:18:45 PM
Or you whip the horse's eyes every time you ride, like say on a rally
Quote from: carsick on March 29, 2011, 10:51:45 PM
whip it , whip it good. :biggrin:
You must whip it,    Crack that whip ...
