rpm's drop
Started by wills89fj1200, March 21, 2011, 07:48:55 PM
why do rpms drop?
ignition
1 (50%)
coils
1 (50%)
Total Members Voted: 1
Quote from: RichBaker on March 22, 2011, 10:07:39 PM
Should be 2nd groove from the top.... you're too rich on the needles.
Rich,
         The needles I supply are the O.E. profile needle with the adjustable slots. As seen in the picture below;
You can see the stock needle position is the center position. So, by raising the clip up the needle range mixture would be leaner than stock.
Quote from: wills89fj1200 on March 21, 2011, 10:40:20 PM
I set it on the 2nd down from center.
Will, if you are at the bottom groove, you are probably too rich.
Quote from: racerman_27410 on March 21, 2011, 09:49:24 PM
Murphy's law # 2    ..... the last thing you touched is probably the thing causing you trouble. :unknown:
Frank,
That's Hoffman's Law #2.  Every time he calls me with a problem, my first question is: "What was the last thing you fixed before the problem started?"
Quote from: racerrad8 on March 22, 2011, 10:35:29 PM
Rich,
Didn't realize that....
Quote from: SlowOldGuy on March 22, 2011, 10:45:54 PM
Frank,
LMAO..... i dont want to give Jefman too much credit but you are absolutely right in that he fits the description perfectly.
