How to check charging?
Started by fjman, March 12, 2011, 12:29:51 AM
fjman
I'm not really much of an electrician. How do I check the charging system of a bike with a voltmeter?  :wacko1:
oldktmdude
  Connect positive lead of the meter to positive battery terminal, connect negative lead to earth or negative battery terminal, set meter to read 20 volts DC. Take a reading of the meter with the engine not running. Should read around 12.5 volts. Start engine and take another reading. This should read higher than the first reading, around 13 to 13.5 volts at idle. Increase revs and reading should rise to around 14 to 14.8 volts. Regards, Pete.
1985 FJ1100 x2 (1 sold)
2009 TDM 900
1979 Kawasaki Z650 (sold)
2001 KTM 520 exc (sold)
2004 GasGas Ec300
1981 Honda CB 900 F (sold)
fjman
thanks for the reply i'll look into it  :dance:
fj1250
Do the lights get brighter when you rev the engine above, idle?
then it's charging!
MC
fjman
TheRadBaron
If the lights don't get brighter when the engine is revved, that points to the charging system not charging.  A voltmeter would still be a better way to verify, though.
The desire for safety stands against every great and noble enterprise.  -Tacitus
Quote from: TheRadBaron on April 07, 2011, 08:53:17 PM
Perhaps to troubleshoot why it's not charging, otherwise, what's the point?      :unknown:
If it's not charging, it's not charging.
srutherford
Spo my bikes lights are supposed to get brighter as elms increase? I thought I had a problem shwew
