How do I take the airbox out?
Started by jmt476, February 16, 2011, 07:28:37 PM
jmt476
Hey guys, I've decided to swap the factory airbox in my '92 for a cone filter setup. The only problem is that I can't figure out how to get the darn thing out. I assume that the side pieces detatch, but if that's the case then I can't figure out how.
Thanks guys,
Josh
1992 Yamaha FJ1200 ABS
1978 Triumph Tiger 750
2004 Ford Mustang GT
1986 Porsche 944
The airbox is all one piece. Remove the two top bolts on the sub frame allows the sub frame to be rotated down a bit. This in turn makes air box removal roughly 1000% easier.
Good luck,
...and if you haven't already bought them consider the UNI dual pods instead of the K&N junk.   :good:
Kopfjaeger
dan thats lazy!!! :blum1: take em all out and remove the subframe... then while you are there you can clean clean clean all those bits you can never get to.... :good2: :rofl:
A sawsall makes the job much easier, take it out in many little pieces ;)
jmt476
Unipod is what I meant. I've heard a lot of good things about them on the site. Is it one filter connected to all four carbs or one filter per carb? Oh, and I'm liking the sawsall idea.haha
1986 Porsche 944
Quote from: jmt476 on February 17, 2011, 08:18:32 AM
One filter, two carbs.
The sawzall idea is good, but makes a lot of shavings to clean up...
