Gas leak...no clue why
Started by jmt476, February 15, 2011, 05:07:36 PM
jmt476
Hey guys, I've got a '92 FJ1200. It's been running rough so today I decided to take off the carbs and clean out the bowls/ jets. I took the assembly off and proceeded to do my cleaning without much of an issue. I put it all back together, hooked them back up, put the tank back on, and figured I'd see how it sounded. I hit the start button, and gas started to leak from the general are of the carbs. I pulled the tank back off and checked everything I could without removing the carbs again, and it all seemed fine. I didn't have time to continue working so I parked it and figured I'd dive into it again tomorrow. I'm really lost as to what it could be. I searched the site but didn't seem to find anyone with the this exact issue. Any and all help would be greatly appreciated.
Josh
1992 Yamaha FJ1200 ABS
1978 Triumph Tiger 750
2004 Ford Mustang GT
1986 Porsche 944
Travis398
Assuming you assembled everything correctly I would guess a stuck float. A few taps to the bowls with the back side of a screwdriver usually works.
jmt476
That may be a rather optimistic assumption..lol I'll give that a try. Thanks man
1986 Porsche 944
Stuck floats are common as ... common things.
Easy fix.
92 has a fuel pump.... you did connect the fuel line? (sorry had to ask)
no splits in fuel line?
this is the reason why i like the Uni pod filters.. without the airbox in there it becomes much much easier to service the carbs.(and tap on float bowls  :good2:)
SlowOldGuy
A few things can cause the leak you describe.  Sometimes after a rebuild, the fuel pump models will leak on the initial filling of the float bowls.  Usually this is fixed by just cycling the key.
It cold also be a stuck float as has already been mentioned.
A third cause is a kink in one of the overflow hoses.  On the fuel pump models, this will pressurize the float bowl and shoot fuel up every circuit into the carb throat and out the air jets into the air filter.  Make sure all the hoses are routed smoothly around to the rear of the motor.
Hopefully it's just an initial filling leak.
I carry a 12' length of steel rod in my bag at all times to tap the fuel bowl of the offending carby when it starts leaking.  Has worked a treat for the last 35,000k's and takes 30 secs on the side of the road. I will however look at a permanent fix when I o'haul the carbs. The interval between leaking episodes can be 50K's or 5000K's.  A big rev through the gears sometimes works too.
Noel ( '93 )
Quote from: ribbert on February 15, 2011, 08:00:41 PM
Noel ( '93 )
I hope you missed the " for inches and ' for feet character. Other wise we need to see a picture of the bag on your bike that carries a 12 foot rod.....Then again.....maybe we don't..... :bad:
jmt476
No I didn't disconnect the fuel line, I just set the tank on a box next to the bike. I'll also have to check the overflow lines. There's a good chance one could be kinked. I'm hoping it's that or the float. And I HATE that damn air box... it made the whole process 10 times harder. I also noticed that I need new boots connecting the carbs to the airbox, as at least two have some nasty cracks in them. Would that have any adverse effects on how the bike runs?
1986 Porsche 944
Quote from: jmt476 on February 15, 2011, 08:22:17 PM
besides drawing in unfiltered air ?    no.
uni dual pod filters... Randy has'em ...get some and never dread carb work again.   :good2:
Kookaloo!
jmt476
I'll be honest...I'm really new to the site and have no idea who Randy is...lol
1986 Porsche 944
jmt476
Oh cool thank you. I've been wondering where to go for parts. Much appreciated man
1986 Porsche 944
Kopfjaeger
i hated the airbox till i used the fj files section and just removed the rear subframe. makes life so much easier.
kosage5511
new member, 1st post, go easy.
my 84 would produce a 4" puddle via one of the carb overflow tubes every night.
found problem wasn't needle or seat. the problem was the o-ring seal between the seat and the carb body.
replaced all 4 and not a drip!
