FJR Clutch master question
Started by simi_ed, April 08, 2009, 11:40:00 PM
I need some help. I bought a FJR clutch master from FleBay.  Looks good but, I see the clutch switch wiring is different.  How has this been addressed by one of the prior purveyors of this mod?  I didn't try to move the FJ switch to the FJR master, but it looks like that COULD work.
Any ideas?
TIA,
What I did on Brian's bike is used a multi-meter to see how the FJ M/C switch was setup.  Then used the meter again to find the correct pins on the FJR's M/C switch and wired to correct pins.
Be sure to install a braided clutch line while you're at it.   :)
