not running as smooth as before
Started by Striker, December 07, 2010, 06:33:44 PM
Striker
Hey there all. Well I have an 85 fj that lately has not been running or sounding quite as well or smooth as it did a little while ago. I know that the carbs need to be cleaned and re tuned. I've tried maintaining the bike as well as I know how. Just curious if there are things I need to do regularly for the engine I am not aware of as this is my first FJ. Also, when I put paper or my hands to the exhaust they are not even. The spark plugs though all look the same so hope it's not a cylinder problem.  :unknown:  Just want to see if it's just because the carbs are a little dirty. Appreciate any help!
Old enough to know better young enough to do it anyway!
Travis398
Quote from: Striker on December 07, 2010, 06:33:44 PM
sounds like you need to start there.
Does it stutter? or run flat anywhere in the rpm range?
Does it rev like it did before when accelerating hard?
Could just need a carb synch?
I've got the guages, and the "auxilliary" fuel tank at the ready in case they are needed.
I really like those gauges!  Do you mind me asking where you got them and how much $?
ukfj
Wow thats gotta be the cleanest carbs i have seen
on a bike, :biggrin: nice guages as well.
Ride Safe
1989 FJ1200 3CV. 1987 XV535, 1949 SUNBEAM S8.
1949 EXCELSIOR ROADMASTER R1 .
weymouth399
For $375.00 you to can have pretty carbs, I have one more set in box and ond out of box
Bob W
84 FJ 1100
86 FJ1200
89 FJ1200
5  FJ POWERED race cars
76 LB80 Chappy
93 KX500 ice for sale
00 KX500 ice/dirt
04 KDX220 dirt for sale
04 KX500 ice
08 KLX450 ice/road
72 CT90x2 for sale
Quote from: Marsh White on December 07, 2010, 10:49:26 PM
If I remember correctly, I bought them from a seller on Ebay.......They were a little pricey. I think with shipping it was somewhere around $110......
I really like them though, and were worth the money to me.
They come in a nice aluminum case with a whole mess of various adaptors for most 2, 3, or 4 cylinder engines....
My Seca II required adaptors, wich come with o-rings, and work perfectly....
The thing I like about them most, is they have adjustable needle valves on each gauge so you can remove the "bounce" from each cylinder pulse........I have used them a few times, and they work extremely well.....
I cheaped-out on my auxilliary fuel tank though.
I think i paid $6 at Autozone for a universal radiator overflow bottle. Came with a hanging bracket, and a length of clear tubing.......
I just hang them both on my step-stool next to the bike and synch away. :hi:
Alan ,
that is a james bond tool kit . way bitch'in :good:
Striker
Hey thanks for the help. Yeah I know I should start with the carbs, I was just seeing if there were other things to also take a look at so I could get a list together. Doesn't look like it's been the most well maintained bike so I want to start to get it into better shape. Hey Alan thanks that could be a huge help with the synching!! It still revs ok through the rpm range but there's a little bit of a hum of vibration that wasn't there before. And it sounds a little rough when accelerating. It may be that the carbs are out of synch or something like along those lines.
Kopfjaeger
was going to say those carbs are CLEAN!!!!!! but after my last effort to make my bike shiny and clean and the resulting chaos.nup. she can stay a dirty girl :rofl2:
The nice shiny cleanness of the carbs in the pictures shown here, are in no way a result of any effort on my part........
When these pictures were taken, they were just installed "Virgin" carbs right out of the box......
These are same said carbs that can be had in other posts by Bob W.
All that was required was drilling, and removing the caps that hide the idle mixture screws....adjusting said screws, and synchronize them.......
This was the day before Erich V, and I left for the WCR.
6 months, and 6000 miles later........they still perform beautifully!
weymouth399
Hi Alan
I would have done that for you, but I would of had to open the box.
Bob W
84 FJ 1100
86 FJ1200
89 FJ1200
76 LB80 Chappy
00 KX500 ice/dirt
04 KX500 ice
08 KLX450 ice/road
72 CT90x2 for sale
imikie
get 20 foot of clear plastic tube,bend in halve and attach 5 foot down one side and 5 foot up the other on a 3 inch wide board with cable ties.add 4 foot of water to the tube, tap board until water is equal in both tubes.you will have 5 foot of tube at each end,attach to carb 1 and 2,start bike and sync.do same for 3 and 4,then sync both banks together. adjust until water is equal in both tubes.works well and cost $10 to make.
mickeyboy
